Alloy Wheel Refurbishment Powder-Coating 'The Process' Picture galore
Right, thought it would be rude not to put this thread up after getting my 197 wheels done and pictures of the process
The process is pretty amazing and the results are outstanding
Got them done in Wickford, Essex @ a place called Ulitmate Alloys
http://www.facebook.com/UltimateAlloys
Google Maps Clicky
The owner is a good friend hence why I was taking pictures all day :)
Now I'm not one to 'curb' my wheels but after you lend your car to fellow CS members they tend to come back like this lol
Now I would love to know who in particular designer the wheel locking nut for Renault, personally think he should be shot
Had to use the impact gun to remove them as the nut was slipping and on its way out
so into the garage I go, jacked up and wheels taken off
closer look at the damage, made by CS members (would never of been me)
Next stage was to take out all the valves to deflate the tyres, then all weights removed
onto the tyre machine to remove the tyres. All 4 complete with centre caps removed
Next up was to put these in the acid tank to strip the wheels back to the bare metal
Now this is serious stuff makes your eyes water even when you go in the room
After only 5 minutes it started to work it wonder
After 20 minutes they were pretty much done.
So into the jet wash machine they got have all traces of acid removed
This is a before and after shot
The next step is to Shot/Sand blast them to get them ready for painting.
The finish comes out like this
After all 4 have been done, hooks are placed in the vales, and then placed in the oven to pre heat.
Oven set to 210 degrees Celsius and a timer is set for 15mins
While we were waiting for the oven to heat up, I took a few pictures of some samples done in various colours so far.
Yes I know you wanted to see the beast again in all its dirty galore
sample stand
Don't be getting any ideas
enough of the wheels, mine were ready.
Out of the oven and into the spray booth they go ready for a powdering
Electrostatic charge (some technical term for the power will stick blah blah blah)
all done, check we've not missed any gaps
Then back in the oven the cure for 10 mins
Now I choose not to have these lacquered, its optional when using the powder we used.
They are not a matt or satin finish, but there not super shiny, just gloss.
This is the finished result
and the back done, so all nice a smooth when you come to clean the back of your wheels through the front :)
Tyres back on with new valves
onto the balancing machine
not bad
Weights on and retest.
Spot on
centre caps back in, wheels on car.
Locking nut not used due to crap design
Torque wrench used for tightening
Then all 4 back on the car
Taken home and cleaned
and of course mels endurance tyre shine used
also Poor boys waxed applied
And the end result. Must say I'm over the moon
and with my VX220 he also done
Wow that looks brilliant! Was abit sceptical when I saw they had gone black but that looks epic!
Nice write up. Out of interest was the mating face on the wheel which bolts to the hub cleaned off of powdercoat?
Thanks
Yeah they get cooper greased so the power don't stick.
Looks good mate. Why not have them lacquered though, surely it would offer a bit more protection form brake dust etc?
Its optional TBH the finish is the same if I lacquered them or not regarding the break dust. Just the glossiness that would change
Nice write up that, need to get my speedlines done, satin for me though :)
Im assuming (and hoping!) that the CS member paid for this wheel refurb seeing as he/she is a full spaktard and mashed your wheels?
LMFAO.
Don't blame me for your over enthusiastic oestrogen gland, sunshine.
My hourly rate for canoe polishing has just doubled.
Unlucky !
hi tyler, only just found this threadView attachment 77584 i have these at home if you want them? ive also added some off your pics at the end to my collection, looks very nice, can you polish mine for me, cu about ian soon hopefully:approve:
Interesting. I see that the inner mounting faces were powdercoated.
Apparently, they should not be powdercoated and never are on brand new/original wheels.
Something to do with the fact that the bolts can come loose(?)
Anyone have an opinion on this as I have had a set refurbed elsewhere and they powdered the mounting faces and I may sand the powder off the mounting faces?
Haha, was it Rob (TEG Rob, not Rob Rob) that did it? They look superb mate. How you getting on with the VX?
A light dusting is fine. Had countless sets done like that and they've all been fine. No wobble, no getting hot and falling off (which a few people claim.) Better than your hub face corroding to s**t.
Just check the bolts are tight after every drive and you will be fine!
Ive had 3 sets of wheels that have been powder coated including the face your talking about with out problems.
They look good Tyler. Nice write up too :)
Ill be showing Russ this as he's yet to have he's done and I'll try and convince to go here ;)
Thanks, yeah I did talk to him briefly about it at north weald.
No pictures of the curbing repair? This bit interests me.
Its done in a sand blasting machine, basically its a sealed unit that you put your hand in gloves through, inside is the wheel with a hose that fires compressed air along with sand/broken glass/walnut depending on what finish your after.
This process gets rid of most of the curbing, any chunks that are missing need to be filled using x and DA'ed back down to the shape of the wheel
Cheers Ian, already got black centres that are on the car :)
This is not always the case, but is easily over come by putting copper grease on the back so the power won't stick.
Thanks Luke, no was neither lol.
Was actually me :) but couldn't admit to doing it haha.
But in my defence it was done in France where everything is on the wrong side of the road so you have to get very close, hence this happening
So think that should be acceptable :)
Loving the VX in the right weather, still driving the clio to work due to rain etc, but when its nice I do love taking to VX.
Gets quite a lot of attention and people asking what it is, that I didn't expect. Suppose I'm going to have to get used to it lol
Great write up mate :) You keeping the clio now?
Glad your enjoying the VX, saw you spotted over on .org getting some VX loving the other night :)
I am hoping to be joining you very soon still :D
No not keeping the clio, getting ready to sell soon, got 3 cars ATM need to get it down to 2 asap, insurance are loving me lol
Yeah the VX gets some right loving, just been down Southend with the roof down :)
I'm waiting for the day you join, ready to go for a summer drive :D
