aucky
  N
s**t just got real
  182 Cup
So the 2.0 16v bullets, are they actually metal, or is it just shiny plastic? Asking as they need some attention, and I'll either use some scratchx or metal polish, depending on material.
Also, going to be a while till I can get any swirls properly sorted out, currently use SRP before a sealant, is there anything I can use by hand that will hide swirls better/sort them out a bit? :)
Gally
It's been around for years mate. The likes of Sonus Carnauba spritz is a better alternative and looks immense.
Gally
Very good for that price mate. It used to very well used years ago! Also great as a clay lube!
Gally
I don't use a spray wax a such. For heavy carnauba waxes Field Glaze is the best but it's also the hardest work.
Vics Detail spray is one of the best I have used, Sonus Carnauba also leaves a stunning finish and so easy to use. Z6 for anything else really.
  Honda & VW
I nearly bought some Field Glaze with the last order I placed but never ended up getting it, ended up buying too many other bits that I "needed". Might give it a whirl next time I am buying more bits
Gally
It's not cheap and it needs practice to perfect as it's "thick" so to speak hence the heavy carnauba and the look it gives. On very warm panels it won't work great but then again neither would a wax.
Clay Lube Citrus Bling mate. It can be used for so many thing. Not as cheap as Demon Shine obviously but much slicker and cheaper than "Clay lubes".
  M2 Comp
Going to give my Titanium 182 a mini detail (if you can call it that!) tomorrow, first time since I got it. Quick question though, LSP - Z2 or Carbon?
Gally
Z2. 2 or 3 layers mate. Nice and thin.
Watch the Z2 application video on YT if you haven't already.
Gally
Pretty much mate. Choose either or really. I prefer tripple more because it cleans.
Gally
Perfect. It comes alive by DA. It'll surprise you how much better it is.
Knuckles
Allo, been searching here and dw but as always, I consult Cs before making a decision...
bought some TARdis and iron x tonight, just a quickie about use;
do I wash, detar, wash, iron x, wash, clay then polish/wax/seal?
and can ironx be used neat on paint or does it need diluting?
cheers
Gally
It doesn't need diluting mate.
So what I suggest is after the initial mincing around washing etc de-tar x2 dependent on condition, pressure wash, de-iron. Wash/snowfoam then clay. Clays can be fussy and fall apart with things like Tardis etc on the surface.
MatthewR
cheers
I usually wash, iron x, rinse, de tar, wipe over with mf pad, rinse, clay, wash polish rinse, dry, seal
Iron x comes ready diluted to use straight away.
Knuckles
Cheers :)
you should see the amount of tar on my car, it's covered lol
brilliant, thank you... I'll remember to get a face mask for iron x :eek:
Gally
Or not de-tarring properly.
It's usually followed by... "it's getting polished anyway"... well done on missing the point.
