EPAS on 172 Cup
I got an MOT advisory on the track car for slight play on inner tie rod. Kinda expected as they have done 118k
I could get them both replaced at BTM same time as I get cambelt done (end of summer) but I had a thought
Looking through BIGASH's build thread I really want to swap my PAS rack for a manual rack and EPAS column.
I've seen the Clio diesel EPAS column is a bolt on part and you can connect the EPAS ecu to a kit from ebay to allow you to vary the assistance - which is all cool.
But the rack itself - I know the Cup has longer inner tie rods - so would I have to buy a base model manual rack (or a diesel one) and then fit new cup tie rods?
Kinda thinking about buying a rack, fitting new rods, then swapping it onto the car with new rack bushes etc... to give the car a steering overhaul
The tie rods can be fitted to lower model racks iirc, my preferred route would be and I know it will be frowned upon is to fill the Cup rack with fluid and make a bridge pipe for it. Beefier rack and supposed to have less turns lock to lock.
Hrmm that was my other thought - I'm sure I've seen a few people before just put a pipe between the inlet and outlet on the PAS rack so it runs without PAS
I didn't realise the Cup rack was less turns to turn though - I thought the diesel rack was slightly quicker
Just had a look and you're right - the non-PAS racks are more turn to turn lock - so that would be s**t
Sounds like my best option will be to drop the subframe off - whip the rack off, fit new tie rods and new bushes, fill with fluid and fit a loop pipe. Then an EPAS rack from a DCi - job should be a good un :D
My mates done this an crispy has aswell. Very good feel through the wheel when on track and up to speed but seriously heavy when trying to do manuvers. People often choose to use the 1.2/dci manual rack to help make the steering a little lighter.
I have done it to although I haven't driven it yet, make sure its filled with fluid as the difference with and without was crazy just pushing it around my lock up, I used a syringe while slowly moving the rack from one side to the other and then made and fitted the pipe to bridge the piston. I filled the pinion with grease as well and blanked just to be safe.
Ah I see, we'll maybe my mate didn't do it like that, I know he put grease in the rack before sealing it but not sure how thorough he done it, maybe his is alot harder than yours.
Yeah that's all he's done, it is proper heavy on the steering lol. He let me have a go around brands a few months ago and the feed back through the wheel was brilliant, very confident inspiring but too heavy when manuvering for my liking. Difference is his is a full stripped out track car toy and mine a daily, that's why he puts up with it because he only really drives it on track.
Got a link to this eBay kit?
Also have you considered using a saxo power steering set up like the burpspeed boys?
Yeah but it still means having fluid pipes around the place. I quite like the idea of undoing 1 bolt and being able to drop the subframe off the car with the rack still attached :)
Do trophy use different racks to normal 182's then?
Do they need a electric feed or are just a basic manuel rack?
Edit : I can't see the twingo rack working without a lot of work.
You lot need to stop playing around with these cars and get them out there. There will be no fuel left in the world to drive them at this rate.
True but nice to simplify the system, I wasted a day of my life on sunday that I won't get back on removing a subframe due to Renaults stupid design.
column!!!
f**k me - 12 straight hours of coding yesterday, I couldn't even put a post together LOL
I'm pretty sure it's just upside down :)
Hahaha I'm not tinkering just for the sake of it - there's quite a bit of play through my steering :(
Seems more work to fit another PAS rack and bleed it all etc - considering what an arse it is to get the rack and PAS hoses onto the subframe etc... than it would be to just chuck a couple of hundred quid at it and a weekends work and convert to EPAS.
I'd be inclined to try the twingo rack and no epas. Can't be any different to my old 205 gti or xr4i that were fine without pas.
I'm the same mate, I'm of the age where I've driven cars without PAS and can't remember it being that bad. I think the reason guys complain about overly heavy steering is because their using the hydraulic racks and filling them with grease. We'll see how it goes, I do have a EPAS column to go in but I'm not sure whether to bother :/
Been pricing these bits up since I got my advisory on the MOT for play in the steering
Twingo rack - £50
DCi/1.2 clio column - £45 approx.
EPAS wiring box - £45
But then the Cup Inner Tie Rods appear to be about £50 per side! then 2 track rod ends which again are £45 per side from Renault, and 2 new bottom ball joints
Looks like being a £300 job to refresh the steering system... eeek
Also once I've lost the PAS pump and all the plumbing - what do I do about the alternator belt? Do I just buy a smaller one and use the alternator bracket to tension it?
You can get Lemforder track rod ends from ECP cheap at the moment, they have a deal on..
Either genuine Inner arms or they do a cross reference from a motor factor from a Kangoo.. Could make things a bit cheaper..
Twingo rack - £50
Optomistic numbers for all that work but if you can then £300 is cheap considering the complete overhaul your getting.
The belt re-routes to avoid pas pump. Piece of string around pulleys when the alternators on minimum adjustment will give you your length.
No I wouldn't buy the TRE's from renault - but I believe you have to buy the inner tie rods genuine as they're longer on the cup?
Do you know if that rack part number is ok Fred? I wanna get it bought before someone else does - RS Twingo rack's seem rare lol
Looks like the column will be £75 as I need the ECU too - but yeah priced it all up tonight and it comes to £290 in parts, then just my own time at weekends on top :)
Do you have to drop the subframe to take the rack off?
Got this tie rod in front of me, perfect copy part for the 172 cup. Not the best make being Firstline but okay for iirc £13 from micksgarage.com
You don't need to drop the subframe but I would highly suggest it having spent too many hours last week on my back removing all the pas hoses, far too busy around that area with the heat shields etc.
hehe yeah I remember from fitting the 182 manifold how much of a PITA it was
I think you can lower the rear section a few inches without fully removing the subframe which should help me get all the pipes removed
Thanks for the part number - I can't make my mind up whether to fit some cheap pattern inner tie rods considering how much of an ass they are to replace or whether to just bite the bullet and get renault ones from wests...
Considering like you said the whole conversion is gonna cost me less than £300 and that's a bit of a bargain for a complete steering overhaul
Oh I forgot about rack bushes - I assume they are a renault part only too?
Yeah rack bushes are dealer only. I checked mine on my 106,000 mile Cup and there was no signs of wear or anything, best to check tbh.
