182 Cup running rough after Green filter Install.
Car  Black Twingo GT
Hi Guys,
I fitted my Green cone filter yesterday and a moment ago popped out to the shops to find it was misfiring etc when I started it. It ran lumpy...
When I removed the airbox I took the cold air feed from the bottom with it but left the pipe on the right (to the front of the battery) at the front which head into the bottom of the bumper (which I believe is a cold air feed).
Can anyone advise what the problem might be? It was running find prior to the cone, its only done 6k miles.
Is there a plenum on the air intake pipe at the front which has a sensor or anything I should be aware of? Or do I have to reset the ECU? (and can I do this without taking off the battery).
Thanks in advance
Dan
