after using clay can it be used again ?
Car  M135i
Ive just got myself a meguiars quick clay kit to clean my wheels mainly as there is alot of crap that wont come of easily on them (probably because there white). I was just wondering if i need to use the whole bar and that once ive finished with it would it be possible to to save it and do the car at a later date ?
Thanks in advance
As long as you keep it in a sealed container/bag then it should be fine.
Also, check its not covered with crap, as you wont want to reuse a dirty clay bar :)
cool thanks mate, willl do my wheels inside and then keep the clay contained somewhere then and wait a while for it to bloody warm up !
I would put it in a tupperware type container if you don't plan to use it for a while as it can dry out.
as above, use small pieces and once they are full of bits you have to throw it away, dont make the mistake of using the whole bar in the first instance
Dont use the same bit that you have used on the wheels!!
By all means keep it for the wheels in the future but NOT your paint.
Just cut the bar into 3 or 4 pieces.
I keep the old pieces of clay to do the windows and glass.
