Trophy Turbo :)
Well I purchased clio trophy at the end of 2013 with a few minor faults and tlc needed.
I've been so busy with customers cars that I've not done any thing to the car what so ever apart from change the oil and filter and stuck some d's 2500 pads and PF fluid in her and went to knock hill.
After missing 3rd gear I shone a synchro and now the poor girl crunches into 3rd when at 6000 rpm
The belts need doing and the dephaser is rattly, the clutch release bearing Is noisey and is documented from two years back that it was then.
So today after a MUST do this and awaiting parts for jobs we've started the engine pull to do all the bits on one go.
Piper cams
Adaptronic ecu
ported and polished clioturbo inlets
Clutch
Gearbox that's been re furbed
Pure motorsport gearstick
PM strut tops
Valeo clutch kit
Dephaser
Timing belt
Aux belt kit
Spax sxr coil overs with sachs going to refurbished and to keep with car.
Piper cams
Adaptronic ecu
Clutch
PM strut tops
Valeo clutch kit
Dephaser
Timing belt
Aux belt kit
