Aucky's Trophy.. Progress Thread
Tullyvernon
Northern Ireland
  Williams, Focus RS
Not sure where the graph is tbh! Iirc it was 190bhp at last measure. (rpm limit still set to 7500rpm)
Thanks, apologies if I missed that along the thread
Are you still running standard cams?
Tullyvernon
Northern Ireland
  Williams, Focus RS
No it's on 197 cams currently.
I see, I was planning on going for the JMS intake at the time they were being planned, but then went for the FRS so didn't bother in the end, they seem to be a good enough mod.
aucky
  N
Things are happening.
aucky
  N
On Trophy Sachs and Mark Fish springs I managed to run 16mm and 10mm spacers (front & rear respectively) with ET35 wheels.
However with a lower ride height and brand new tyres I have my doubts about clearance.
^poke.
So my Renault/Oz F1s are going for refurb. The lower offset should fit.
Somnambulist
  172 Cup
Fantastic read, very inspiring. I've just taken my Sachs off for a refurb with BG and need a new set of springs. Would you recommend Mark Fish? Tried them on circuit yet? Hoping I'm going to have my Sachs back in time for the Renaultsport track day at Oulton next month.
aucky
  N
I can say I've tried them extensively on track :)
Yes I would recommend them, they aren't really any more harsh than the standard springs but offer a nice drop.
I believe the Eibach Sportline give a more compliant ride on the road due the progressive wind, if that interests you. Not too sure about the cooksports though. I don't know of anyone who has them on Sachs.
Somnambulist
  172 Cup
I can say I've tried them extensively on track :smile:
Great thanks aucky! Mark Fish it is then. I had never imagined that these little cars would be so addictive. Or so much of a money pit...
aucky
  N
Interior is 90% back in with the cage. Looks like I'll have to modify the rear door cards to fit around the cage.
Whilst it was out I gave everything a good Hoover and wet-vac.
aucky
  N
Quick headlight refurb this morning.
Not 100% perfect but good enough for now.
- 2500 grit by hand, lots of water until the grit was very degraded
- 4000 grit sanding disc with lime prime plus
- Menzerna PG1000 worked until fully diminished (lots of water top ups) on a green 3M pad and finished with lime prime plus
- Eraser wipe downs and 2 x coats of CQUK14
That'll do pig.
aucky
  N
Based on this:
With 600mm from bar to collar bone, the harnesses should cross over with a 50mm spacer between them?
Thought I better ask because most Clios I've seen tend to run them in parallel.
@NorthloopCup
NorthloopCup
Based on this:
@NorthloopCup
Measure the distance from the back of the seat mate not from the collar bone. You may well find that its 500mm or less, so in this case you don't need them to x over. I've never seen them crossed when a harness bar has been used in that position tbh.
  Clio 172 & BMW 335D
It's most of the benefits of ITBs with none of the drawbacks. For a road going car with cruise control its a good option. If you want all-out power and do mostly track days the. ITBs are the better, more expensive option.
What bhp do you think you are running with it?
