imprezaworks
Mk5 Golf GTI :)
Probably. Chem glaze then wax by hand.
do you find it alot quicker ive still got mine in the boot its been paid for by my pal but tempted to go over the miniProbably. Chem glaze then wax by hand.
thats it did the clio took a day n half lol would like to do the mini but a glaze is screeming f**k the swirls cover them lolDefinatly not quicker lol. Better but not quicker. But then I tend to fook about too much.
Once the initial compound stage is out the way, applying the polish is easy enough. I still need to do the roof and bumpers.
100% do it yourself if you get time and can be arsed.
Dat arch gap tho!
They do look good though, even with your car being that high, they'll obvs look better with lowzzzz.
What ever spacers @Dr Jekyll has got on his to make his final offset, go for that. Although his 2118s will have a different offset to yours so you'll need different size spacers but as long as you get to the same final offset itll be sweeeet.
That's a lot of spacer.He has 165mm spacers and his wheels are et38
Always wanted them anthracite as they do look the best on bg! They did come with some centrecaps the same as yours yeah, will probably give them a lick of paint and see whether I like them on or not. Did you hold yours on with silicone? As these looked to have had some on. Not sure on the decals however you can see the remnants of them on the wheel where they've faded. A go over with a DA would get rid i'm sure. Unsure on what colour would suit, unless I just went for a slightly darker anthracite.165mm?? Widetrack yo!
@Louis' The car looks awesome on the 2118s. Best colour with them suited on BG Will you be adding some decals to them? And/or the "center caps" like mine has and also had on my old BG?
I'd be sticking with 10mm axle spacers for yours and 20mm fronts. I have 16mm fronts amd 5mm wheel spacers on the rear (i chose wheel spacers as i have the center caps and I needed to fill the gap as they pertruded a bit, and the axle spacer wouldn't have pushed the wheel out closer to the caps) but as others have mentioned, mine are et38 so stick out 5mm wider. So my 16mm/5mm on et38 would be pretty much the same as 20mm/10mm on et43. Does that make sense?
the fronts was held on via silicone as they didnt fit snug in the spacer like the rears didAlways wanted them anthracite as they do look the best on bg! They did come with some centrecaps the same as yours yeah, will probably give them a lick of paint and see whether I like them on or not. Did you hold yours on with silicone? As these looked to have had some on. Not sure on the decals however you can see the remnants of them on the wheel where they've faded. A go over with a DA would get rid i'm sure. Unsure on what colour would suit, unless I just went for a slightly darker anthracite.
Makes sense on the spacers, cheers Mark. I presume I'll need longer bolts if fitting wheel spacers, but would probably just upgrade to studs anyway as I hate having to mess around holding the wheels up when changing them.
Thanks mate, glad I stuck it out and waited for these!They look fantastic
Makes sense mate, knew there would have been a reason.the fronts was held on via silicone as they didnt fit snug in the spacer like the rears did
What springs are you running?What you thinking for lows now then Louis? Personally 2118's don't do anything for me. I'm even thinking of selling my 15's as without coilovers I think they look too small. Definitely a dilemma.
Nope they do nothing for me at all. It looks OK on cooksports though, that doesn't help me decide either!
Do that ^
What were they on mark?
Has anyone ever used ktr coilovers? I currently have those on my 172. But it seems that the right side is busted now and the left side is bent slightly (referring to front only) because I can't raise the ride height beyond a particular point.
I was thinking to purchase another set. But not sure what to get
Sent from my ONE A2005 using Tapatalk
Noted. ThanksVmaxx my man. Not the best bit did me ok for 2yrs.
Don't get cheap again. Save/spend more money on a better set. Buy cheap, buy twice when it comes to coilovers on these.
I'm getting the car on some ramps this weekend at my brothers work, then going to drop the whole system and start again with fresh/cleaned clamps and new silicone. All mounts are new/polybush so it should theoretically sit properly. Will weld up everywhere that needs it.You could do the hoover trick like what I did to find outwhere the blow is coming from.
When did you last have the car tracked? It'd be worth jacking the car up at the front and checking everything to see if anything loose.
