Thought i'd update.
Got the new AD08R's onto my new 2118's. Kwik-fit were brilliant, cannot fault them one bit! Lad who fitted my wheels was very careful and made sure there was zero damage to the wheel. They used a new head on the machine to minimise the risk too.
	 20180512_095855
20180512_095855 by
Louis Walker, on Flickr
Even fitted the AD08R's properly with the yellow dot by the valve.
	 20180512_095730
20180512_095730 by
Most wheels balanced up fine, but one of the tyres took a little more weight than the others. Pretty strange really, hope I experience no problems.
	 20180512_095744
20180512_095744 by
To get them ready for fitting I cleaned them up with some Carpro Eraser then have finished them up with some Gyeon Rim quartz coating. I've done two, need to do the others when I get time!
	 20180514_200915
20180514_200915 by
When I got back from Kwik-fit my passenger window decided to stop going up. Removed the doorcard to find this...
	 20180512_112928
20180512_112928 by
A quick bodge sorted me out for a few days before my regulator arrived
	 20180512_123536
20180512_123536 by
As the doorcard was now off it seemed a good time to get some silent coat sound deadening inside there. There was a noticeable improvement to the speaker quality and there was slightly reduced road noise after refitting the doorcard.
	 20180516_175452
20180516_175452 by
I got the new regulator back in place at the same time. So frustrating not having a working window but thankfully an easy fix. Much better than some other cars where the window is bonded onto clips on the regulator. Renault did good here with a hole in the glass.
Next up was fitting the black insert headlights that I had been sitting on for a while. They were sanded right back and polished up before fitting but halfway through I found a broken clip on one of them... So I cut one from my salvage light, cut it until they both mated up correctly then plastic welded it into place. It was then backfilled with epoxy to strengthen it further. Worked great!
	 20180520_081910
20180520_081910 by
	 20180519_181744
20180519_181744 by
Bumper off
	 20180519_140620
20180519_140620 by
Swapping over the Silvervision indicator and xenon Osram bulbs
	 20180519_140628
20180519_140628 by
Both on and after a quick wash
	 20180520_155611
20180520_155611 by
	 20180520_155559
20180520_155559 by
	 20180520_155621
20180520_155621 by
	 20180520_155627
20180520_155627 by
Very subtle but much better than the grey when against the BG!
I had intended to dip my bonnet catch into some deox-c but a cheap genuine unused catch came up for sale on the fb groups for £12 so I grabbed that. Even came with some new genuine nuts!
	 20180517_124933
20180517_124933 by
	 20180520_163250
20180520_163250 by
Gave the whole engine bay a going over with a detailing brush and some Autoglym engine cleaner.
	 20180520_163229
20180520_163229 by
	 20180520_163240
20180520_163240 by
Will be changing all the the rusty bolts on the crash bar at some point as they do let down all the bay.
This also came up cheap, i've started cleaning it but still not sure whether to fit it or not!
	 20180517_125511
20180517_125511 by
I have a ph1 stalk to go on anyway so will fit this whilst I'm there! I like the one I have fitted now as the lettering is engraved much further.
Finally, I managed to find some genuine clio aerial gaskets that are for the clios with the satnav aerial base! These are ultra rare and I had to get it from Germany but I can't wait to get it on the car as the gap that is there currently is awful.
	 20180515_172449
20180515_172449 by
