182 trackday racer
Have seen several conversions on 172/182 cars using Brembo calipers from 197/225 Clio and Megane. The problem seem to be the standard disc diameter is to small making the manufacturing of the adapter hard. I have seen a solution for this, and looking in the exploded views for the Twingo R2 I can see the solution is taken straight from the gravel setup for this car (attached image) So thats for using standard 280mm discs, but I want to go bigger than that, standard solution seems to be using Scenic 300x24mm discs. But those are a bit to thin to be ideal and still have vents from the outside.. Was thinking about AP racing discs and making own bells, but then I saw the tarmac discs for the R2, 300x27mm and the bolt patern seems to be the same!!
Maybe even the R2 adaptors and the discs will be bolt on to a 172/182??
