Can i remove 182 oil filter without droppng oil
  immaculate clio 172
Morning guys as title really
Will I be faced with a big mess if I don't drain the oil when removing filter?
Changed oil couple days ago but couldn't get filter off
Now have a decent wrench so ideally just want to swap the filter over and leave the fresh oil in there!
  182, SQ7, Trafic
Well that was a silly thing to do wasn't it, should of just waited.
If car has been sat for a few days or so you "shouldn't" loose much.
  immaculate clio 172
Yes ideally would have waited but needed the car and never saw the filter removal as being an issue 😂
Will jack front of car up again too which should help
Just cant be bothered with dropping oil again and needing another sump washer!
R3k1355
You'll dribble a little bit of oil out the filter, but nothing much - should clean up fine.
You'll need to double check the engine oil level after swapping the filter.
  Clio 172, Escort RST
As above.
However, what wrench do you have? A number will not fit without wrecking the sensors in the process. A fluted tool which sits on top of the filter of a stap tool (not chain ; it's too thick) seem to be the best ways to go about it.
Crybert
  Cup 172
I find it crazy that you just completed the job without getting the filter off. Just hammer a thin crew driver through the thing and lever it off. Dead easy.
Anyway as said you won't loose too much, will maybe need a small top up after its done
Crybert
  Cup 172
Don't hammer a screwdriver through it. If it shears off you'll be left with a piece you can hardly get hold of.
It won't shear. Hammer a lon screwdriver through it so it comes out the other side then use that as a lever. I've done it a good few times and never had any issue. I'd be concerned if the filter was to shear..
Mr Trailer Man
It's a pretty much last resort thing.
I've never had trouble with a decent filter wrench.
Crybert
  Cup 172
Yes I always start with a filter rench but had to do the screwdriver trick on a Clio trophy and r26. Think the filters had been on for a good while
  immaculate clio 172
What's so crazy about it!
I drained the oil from Sump them came to remove filter but it wouldn't budge
That's generally the order you do an oil change on a car
Have put the fresh oil in and now hoping to swap filter out when I get suitable tool for the job etc
  • Like
Reactions: DrR
  immaculate clio 172
Thanks for all replies chaps
Hopefully get it off tomorrow!
Anyone ever used one of the 3 leg type filter tools on the 172/182?
R3k1355
Go find one of these, it's supposedly the tits for removing the oil filter
Cup Oil Filter Wrench 76mm / 12 Flutes -single
SKU: 000980581£5.83
  R5gtt, 182, volvo...
Screw driver it...
I've got a few filter wrenches and sometimes have to bust out Philip and the Thor. I'm sure some people use the wrench to fit the filters because they're tighter than a nuns bifter.
I can appreciate where James is coming from. I once tackled a very very stubborn filter and the screwdriver eventually tore around the filter and left the base and a mangled mess of metal. Luckily it was just on an old block and I managed to chisel it off.
  immaculate clio 172
All done chaps
Bought a 3 leg type this morning and off it cam
Was very very tight though
No oil lost either which is a bonus
Full Service complete
Rear brakes changed
All caliper sliders checked and re-greased
Car washed, polished and waxed
Thanks again
:cool::up:
R3k1355
Screw driver it...
No I think it's something to do with the heat or something??
Happened all the time on my last car, it got serviced 2 times a year so the filter hadn't been on for very long, always primed the seal with a little old engine oil, always installed the filter by hand, never over-tightened it.
Every f**king time the filter needed a removal tool to get it off as it was on so tight.
Done that before myself on a 306, was absolutely fuming as I needed the car to get to work the next morning.
Managed to get a chain-whip style one on the remnants and shift it off, was so relieved!!!
