Chris's 172 Cup Turbo
Just be mindful of the post cat sensor. Mine was fine, then this weekend I fitted a new exhaust which has made the cat sit higher, that and pulling the engine forward has pushed the post cat sensor into the heatshield and gear linkage which then blows the fuel pump fuse when it shorts. Now I need a new sensor!
Thanks all. Have tried and tested yet, but, I did manage to move the engine forward a fair bit yesterday.
Also had a chance to photograph top mount setup. Does all look correct?
These are the top hats. The nut appears to spin on one of them but is fixed on the other. No idea if that’s correct.
I’m sure that it’s separate to the knock and hopefully the engine position is the culprit. Will try tomorrow when the weathers improved.
So, i've taken both shock absorbers out, and unassembled both. The passenger side spring looks like it had been compressed to the point that the bump stop had split in two. Should the spring be compressing to the point that the coils rub together? (pic below)
Measures taken so far to try and cure this issue:
- New top mount bearings
- New upper gearbox mount
- Polybushed dogbone
- Swapped to OEM dogbone
- Swapped back to Polybushed dogbone
- Triple-checked steering rack bolts are tight
- Moved engine forward and tightened down the engine mount
Knock is still there. I will be booking the car in to be looked at by a garage... although I am wondering if larger outter arb bushes would help? mine look almost loose. I ordered 23mm outter bushes for reference and the arb on the car when dismantling looked to be new/recently swapped.
Bumpstops always fall to bits on these, as they are used as secondary damping when lowered. I destroyed a bumpstop riding the kerbs at Blyton.
Id imagine the springs are progressively wound so will touch coils a bit.
Wheels off and get at it with a pry bar of at home, you'll soon see something that's loose, much easier on a lift obviously if you can get the use of one
Turns out I was looking in the wrong place. Got my brother to take it to work. The ball joints where the incorrect type, and where moving separately from the arms. Not great!
It’s ok now, however, I’ll likely get some second hand Cup arms as spares just incase any wear occurs again.
In the meantime, I finally got some ramp pictures. Nice to see it from afar, rather than on the floor 🤣
Still a few bits like heat shields and trim to put back yet. When I can be bothered
Not much to update, but I've booked Snetterton for the 13th of August which is exciting. Took the car the scenic route to Birling Gap yesterday - the car was faultless.
No real plans to change it up with mods, other than getting the alignment dialed in properly with AW Motorworks in late July.
Cosmetically speaking, the car needs some love. I don't know if it's immediately visible here, but the door is not the same shade of Mondial blue as the rest of the car. The headlights are faded so will be replaced. The drivers side side skirt is also battered, so I need a new one of those too.
Jobs still to do:
  • Replace headlights
  • Replace drivers sideskirt
  • Replace Aux belt
  • Oil change before Snetterton
  • Camber shims on the rear, camber bolts on the front
  • Fit 172-cup door pillar badges
  • Buy a new stainless exhaust
The list seems to never end, but I'm determined to just enjoy the car for the summer first, having already spent what I paid for the car and then some!
Jobs still to do:
  • Replace Aux belt
Epic.
I’ve done the same (spent more than the cars worth and then some) 😂
Poverty friends
Something I’ve had planned for a while; finally getting married after 15 years.
Naturally, after 5 Cups during that time, it seemed fitting that this one was the wedding car 😂
Got Snetterton booked for August and alignment booked in for 27th of this month.
As it was the big day, I tried to get the car looking as good as possible. So fitted some new headlights. Definitely helps make it look a little more cared for.
Long term I’ll retire the car from track duties and use it as a well cared for example on the weekends - respraying bumpers etc. Hopefully a track oriented 250/R26 will be on the cards.
Took the car to see Alex at AW Saturday last week to get some camber dialed in and the alignment sorted - I'd been driving with the steering will pissed the entire time up till now.
He fitted some Eibach camber bolts and got it to roughly -2.5 degrees. Only 1 shim was needed at the rear drivers side to get it fairly square.
Oh my, what a difference it's made. For a relatively stock suspension setup, it's absolutely sublime on the road. No doubt it will be a little soft on track, but we'll see in a few weeks time!
Did Snetterton on Tuesday. The car was mega. Reset the trip computer before setting off, and managed 340 miles in total.
130 mile journey to the track, topped up the car to full with £26 from the Esso outside, and then did the entire day and drove back on one tank. What a joke :ROFLMAO:
By far the best Cup I've ever owned (so it should be!)
Everything feels so tight and sharp. You really know where you're at with the chassis.
Will be on the hunt for some 15" wheels and AR1's for next year. Also fancy a diff, but would rather put the money toward a Meg.
Spa booked for 2025. Will be doing the 1st of April with Javelin.
I've had the car SORN since October. Will be adding an exhaust and possibly getting a map too before April, as it's over-fuelling big time.
Changed a door
On the left is mondial blue - on the right, artic?
Put the car on stands to give it a deep clean.
Not too bad considering it had been a year - most of this was from when I annoyingly got caught out in the rain about a week prior.
Came up ok - seems durable enough. Will be doing this again. This was just the first pass with snow foam and a brush.
Finally, steering wheel and PH1 stalk fitted for the horn. No other plans on the interior unless I see a scenic shifter pop up for sale.
Roll on next year!
Nice!
Once mines back from the Bodyshop i'll be deep cleaning mine and smothering it in ACF50.
I want to get over to Spa. Watch out for the noise limits re new exhaust. I need to do something about my decat non res miltek that got was going to get me black flagged at brands, but the diff exploded before they got me.
Here's an interesting one.
Has anyone removed the gear linkage and shifter in one, whilst cat/heatshield etc are all still in place.
I've got a scenic shifter to fit, but the new brass bushes I put in are so tight, I can't get it undone whilst it's on the car.
My only option is to remove it in one and pull apart on a vice.
Thoughts?
Thoughts?
Could you not do something imaginative with a nut and bolt/threaded bar to see if you could shimmy it out somehow?
Haven't updated in a while.
Fitted a Piper stealth exhaust system, got a remap, gave it a service, went around Spa. The car made 169.7bhp with ED. Not amazing, also not bad. The main thing is improved drivability and throttle response.
Mixed emotions doing Spa. It's a big track, so even a fast car can feel slow. Key takeaways from the trip were:
  • NS2R's are awful in hindsight.
  • Stock suspension (even with grams) make for a very soft ride on track, but ideal for fast road use.
  • I should have fitted a rear ARB.
  • Book the second day - it's way quieter once certain groups and demographics have buggered off to the ring for the second day.
For next year's road trip:
  • 2118's with AR1'S
  • Rear ARB
  • Coilovers - but torn on this, because the car is so good to drive on the road.
For 2027: K Swap. We've added up what's needed, and reckon 10K will cover it.
  • 2118's with AR1'S
  • Rear ARB
View attachment 1739812View attachment 1739810
Love it.
I’m off to spa next month and hoping the engine survives that long ass straight…. Did you get any footage ?
I’m on BC adjustable and I have to say, on the softer setting it’s better than cooksports on cup shocks… for what it’s worth.
Love it.
I'm jealous! would love to go back. Which provider/club have you booked through?
That straight is something else. I hit about 115 ish, but most of the time backed off to let the faster stuff pass.
Interesting on the BC's - probably the brand I'd consider if I did make the upgrade. I got some. Will pop it in here in later.
The one time I recorded, the car went into limp mode on the second lap due to a throttle body error. 😂
Gold Track mate
  • 2118's with AR1'S
  • Rear ARB
I've got the same exhaust with twin silencers - lovely bit of kit! Just wish the rest of my car looked as clean as yours :D
Great exhaust isn't it! I also opted for the twin silencers too. I am glad I did, because it's loud enough as it is. I am also running a sports cat.
It's honestly not all that clean. Looks better in photos ha.
I have the standard cat and mine sounds just a little bit louder than the stock exhaust. The sports cat must make it loud.
Great updates.
I'm looking for a new exhaust as I find the KTEC Resonated stealth a bit droney.
Love the mic drop of the K swap.
Well... I actually really like them. Would have preferred them in silver, but that's not an option from new.
Pretty happy with how it sits. Thicker tyre walls help for sure. Stock cup dampers and grams springs for reference.
AR1's will be the best tyre that I've run on any of my Cups by a country mile. So looking forward to some dry weather.
Chonky. As you say, silver would have been good, but I'm a sucker for silver wheels.
How's you rate the tyres?
They look good, decent alternative to the 1.2’s. Don’t mind them in anthracite too. Someone else on here has them in gold which look decent as well.
