CNC thread
RSRowe
  Megane 250 Cup
Definitely gonna sound like a stupid question, but what’re you planning on measuring with it?
Beauvais Motorsport
Currently 95% cylindrical parts, profiles, radius’ etc until I take on work. Basically everything an optical comparator does, but with the benefit of being linked to a pc by default, which is perfect for my workflow.
RSRowe
  Megane 250 Cup
What sort of tolerances?
We have a load of Keyence equipment at work, and it’s ok, just not amazing.
Some things it does wicked, but others it just hasn’t the capability to see down to microns.
It’s crap at doing rads, but again, the stuff I’m measuring is like R0.5 and 0.003 max tolerance on diameters.
I think Mitutoyo should be a bit better. They’re ace at after care/support, and also have training shops which you can book in to.
Beauvais Motorsport
Its for reverse engineering so even at 0.01+- It would be fine as some non critical features are up to my own interpretation, but 0.005 would be ideal.
This is the spec of the model I'm looking at.
Andy_con
  clio 182
Ahh do I or don't I?!
Great price, but I'd need to have a big move around in my workshop to make it fit
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Been stripping down and putting back together bits inside of a Fives Landis LT2e over the past few days at work.
Been interesting to see how they work mechanically.
The Scale/Encoder on the Z Axis needed replacing so was a bit of a task getting to it
Touring_Rob
Check out Vision Engineering too, they are in the UK and sometimes their kit goes for cheap on ebay because its not such a well known company. Their stuff is supposed to be very good and they aren't based a million miles away from you.
Beauvais Motorsport
I'm selling the machines, clio for parts and giving up the unit. Its just too far and not insulated, seeing the machines sweat and rust is miserable when I worked hard to clean them up to begin with :(. I'm doing what I can at home for now, I just bought a 220cm oak desk so I can comfortably lay out parts for reverse engineering and hopefully have a vmm on the end.
Beauvais Motorsport
Andy_con
  clio 182
I can't work out why someone would strip the inside, the mill new was probably 30k.
YorkshireKyle
Is there anyone able to help?
I need a 6mm thick spacer 30mm OD and an M12 ID
The ones I've just been sent that are "precision accuracy" grade are less than f**king ideal. It's a stamped pissing washer man
YorkshireKyle
What material are you after Kyle? Looks like a super quick lathe job - there are loads of friendly cnc people here who I'm sure could help @Paulie031 @Beauvais Motorsport @Clio_fool.
Could probably get away with laser cutting if someone has some 6mm sheet in stock.
I was thinking 6060 Ali for the material, but I'm happy to listen to better material choices. The hubs and brakes they're going to be attached to are Ali anyway
How many do you need pal?
Initially 4 for testing and then depending on price I would look at making kits. I've drummed up enough business already for about 10 kits, which would be 44 of them
Might be able to help as well
Appreciate it Jim
JimF
  Clio 172
I could knock you 4 up out of mild steel but I've not got the material otherwise, soz x (y)
