No video of first startup?
This will be mad! Looking forward to the progress. I'm not sure if I've missed it somewhere, but are the custom pistons made to fit standard bore? What CR is being used?
spoke to mikey about a week ago, good to hear you guys are making a go of this, and great to see such a push to develop something straight away,
i should try and stop by as i am still relatively local (on weekends)
Update (again, pictures to come).
Car was running on the standard ECU with 750cc injectors and a 197 throttle body. We are going to be replacing it with an aftermarket ECU. This is for better control and safety more than anything. It does mean that none of the dash will work because of the CAN, however we have some solutions .
Apart from the ECU its all finishing tasks i.e. brackets, bonnet pins etc.
Car should be ready for mapping by the weekend.
Watch this space
Why not run the OE ecu piggyback to keep the dash. That's what I did unless you want a new digi dash.
Awesome build.
Think i saw a mazda at trax today with cooksport on the side? Which sounded utterly mental. It could of said something else though lol.
there's a company called Corksport that makes alot of bits for mazda's?
TBH its probably a relatively common name, there is a clothing company called the same apparently:
http://www.cooksport.com/
We are sitting at approx 450 currently. 1.5 bar, but suffering from boost creep.
Waste gate is 45mm and just can't flow enough. Looking at options.
We will be getting another map sensor shortly to allow us to run more boost.
Teething problems have been; a V band flange blowing slightly between downpipe and front section (Being replaced with new flanges) and some staining on the bonnet from the flames.
Josh
Sounds very interesting, seems so far the bigger TB hasnt proved its worth over the power that pauls was creating. Lets hope with a bit more fiddling you get the results you're after as I'm sure many megane owners would love an alternative solution to more air
What size is the TB?
Ive seen 600bhp on a 48mm one, and a friend has over 830bhp on a 64mm one.
That's good to know as I have a 48mm TB and if its good for 600hp then I should hit my target of 300 no problem.
Sounds like really good progress so far, especially in such a short period of time
The flow problems you are experiencing arent the wastegate butthe pipework IMHO
Ive used as small as a 38mm wastegate and had no problems with boost control on a 600bhp GT35R engine, even when wanting only 10psi flat out, and also fine upto 34psi flat out
So the 45mm is definately big enough if you have appropriate pipework
Likewise I mapped a car with a 45mm wastegate that had horrible boost creep at the top end of the rev range, and it turned out to be a problem with the angle of the wastegate takeoff, at high rpm the gasses were just firing straight past it.
Have also seen similar issues where the angle returning to the exhaust was incorrect too.
So I think you need to look not at the size of the gate itself, but at the angle of the takeoff for it, and also at the angle where it returns to the pipe (if its not on a screamer)
