Dan@SJM's 1720v
Status
Not open for further replies.
Erm, yeh. It was running 32psi when I took it out last night (forgot to select the boost control port on the ecu DOH!) at which point it was going what ever direction it wanted (using 2 lanes of the dual carriageway) and I was along for the ride. But that was with the tracking out etc so it was going to be playful lol.
That'll do...
Assume it will be making it to Bedford as per usual Dan?
Not much will be touching it that's for sure!
Yeh bedford is all booked up, realistically it'll be weather dependent as to how well it performs.
Exterior
Porsche grey black paint
Poly carb windows
Carbon bonnet
Cup spoiler
Interior
Stripped out,
Flocked dash
Clock console replaced with Wideband lambda, boost and EGT gauges
Snap off steering wheel
Safety devices roll cage
EPAS Conversion
Cobra evolutions with Renaultsport embroided
Engine/gearbox
1.8 20vt
Fully forged (crank, rods, pistons)
Stock inlet with ph1 172 throttle body
Custom Tubular exhaust manifold by SAS Welding services with top mounted GT3071r turbo with 4" inlet.
Magnecore leads with 172 coil pack
Specialist components typhoon 2 ecu
Siemens DEKA 630cc injectors
Run on Fuchs Titan pro-race oil
Custom mounts
Zircotec protected engine bay
Heat wrapped and ceramic coated downpipe
300x600x76 intercooler painted black with black hosing (stealthy)
Fancy features mapped in like boost by gear control, closed loop boost control, launch control. Mapped by SJM Automotive.
02M gearbox with Quaife LSD
Hydraulic clutch conversion
Single mass flywheel
Custom driveshafts by GB Engineering
Fuel system
4bar fuel pressure regulator
Walbro 255lph fuel pump as a lift pump
Bosch 044 main pump in-line
Suspension
Bilstein b14 coilovers
Pure-Motorsport top mounts
Pure Motorsport rear anti-roll bar
Roll centre adjustment kit
25mm front spacers
10mm rear spacer with 2 degrees neg camber
Brakes
300mm front discs
Wilwood calipers
Ds1.11 pads
Super blue fluid
Braided lines
Wheels/tyres
Road wheels
OZ F1 with Michelin PE2's in 195/50/15
Track wheels
Dry:
Pro race 1.2 with NS2-R tyres in 205/50/15
Wet:
Speedline 2118 with Michelin Pilotsport 3 195/50/15
does the car come with a spare set of underpants Dan ,must go like stink
Awesome, though the thought of all that torque steer/wheel spin sounds like no fun - anything you can do to improve on it? I see you already have decent tyres & LSD!
Equal length shafts is an option, but it's quite a bit of work as no VW has equal length shafts as standard. I have an idea in the making which will eliminate all torque steer.
Why have I not seen this and what actual f**k. Look at that turbo.
I thought you sold this aswel? Im behind.
Lol nah never sold it :)
Jeez. Mega, Mega build!
My mate has a similar setup in his A3 track car running around the same power and that is bonkers, Can only imagine what this is like with bit less weight!
Any more videos i can show him?
It's at Bedford with me and some others off here this weekend, so I'll try to get some of it from behind with my GoPro. Until it f***s off into the distance, that is! Lol!
I'll put some vids up when I've uploaded them.
So thoughts from anyone who saw/passenger'd in it yesterday?
@AlexW @MicKPM @Edges
It has highlighted a few issues, that I hadn't found on road use, mainly the clutch line needs rethinking as its getting hot and slipping the clutch, 360bhp is taking its toll on 140k old rings/stem seals so it's starting to smoke a little. And it needs a swirl pot, as under hard Cornering it was starving itself of fuel if under 2/3 of a tank.
Much the same for me, was surprised how well it handled, straight line speed compared to a standard 1*2 is amazing.
Epic I though, the speed is insane and the way you steer constantly to go in a straight line is hilarious!
So Roll centre kit fitted (didn't grab a pic so here's a library pic)
I was also having issues with fuel surge, on long right handers if below half a tank. So dug out my old fuel setup from the shed. And I had a spare hour so chucked it in (the red wire was just a mock up to confirm it all worked!)
Status
