Cheers :smile: Yes you do buddy!
Haha thank you very much. I think that was a compliment
I am now taking on freelance work
Thanks man. I didn't actually touch that in the end, just left it as is but that's actually a really good idea.
Tonight i've been tinkering holy s**t it's 12.22! I feel like a student again.
Got my
@bristolnate door cards on. Absolutely beautiful things! I used velcro to stick them on. It's worked really well
Lots of velcro
20160826_190412 by
dann2707, on Flickr
The plastic covering is still on
20160826_193135 by
dann2707, on Flickr
20160826_193347 by
dann2707, on Flickr
Thought i'd go for something different too, people usually use the silver door handles but i'm going for the stealth look
20160826_193819 by
dann2707, on Flickr
20160826_194636 by
dann2707, on Flickr
I also fitted the heater properly tonight. I've used nylon stand off washers to space it out due to the angle of the coolant pipes. Think it looks pretty decent too!
20160826_194747 by
dann2707, on Flickr
20160826_194757 by
dann2707, on Flickr
20160826_194804 by
dann2707, on Flickr
Another pic of the door card against the wheel and seat.
20160826_195447 by
dann2707, on Flickr
Velcro holds it on well, it's nice and straight. Deffo recommend.
20160826_195544 by
dann2707, on Flickr
I also received my switches from RS so started wiring them up. These have to be DPDT as that's how the window operates. Basically when you flick the switch up and down it reverses the polarity of the wires to the motor which either goes up or down.
All done!
20160827_000646 by
dann2707, on Flickr
I then tested it to see if it all works, it does as you can see when im pressing it one way the voltage on the LCD display is negative 12v.
20160826_220108 by
dann2707, on Flickr
Then flicking it the other way you get positive
20160826_220121 by
dann2707, on Flickr
It's so handy having a PSU fixed for 12v output for things like this. Thanks
@Matt555 for the tip with that.
