Daniels Blue 182.
dann2707
I've been in a low boost Clio at Donington and it was bloody rapid!
I feel 300 would be too much? Although the supercharged ones don't feel too bad at 300, more linear power i suppose.
I take it the box has a diff in?
I have to agree mate, 300 would be brutal and at that point where you're wondering what's going to fail next.
But on the contrary it's all set up for it now so it would be rude not to.
May look into seeing if I can get switchable maps on the ecu.
No it's an open diff from the meg.
dann2707
incy-spider
Switchable maps would be awesome, that’s what I’ll be doing when i forge mine! I’d hate to go mental power and loose the amazing 250/240 map I have now, it’s a fantastic balance without causing it to be unsettled and too much of a handful... saying that there are a lot of places on the uphill sections of the ring where I’d like to be hitting the Rev limiter in 5th! (Another reason I envy your 6th gear [emoji23][emoji23])
JamesBryan
Need to get an R26 box or stick a Quaife in that bad boy.
Even mine on standard power it transforms the car.
YorkshireKyle
Could you not setup boost by gear with your ECU? That way then you get the best of both worlds and don’t have to switch maps by toggling through a boost controller etc
dann2707
Ahh that's no where near a replacement for switchable maps is it lol. I'm not going to want to go on a track day in 3rd gear am I when it's wet lol. I'd want a switchable map so that it limits power as I'm going through the gears.
It is on a standalone mate, me221
YorkshireKyle
Yeah basically ^
Like you can set it to 15pounds on 1st gear, 2nd at 20 psi etc etc
Just so you’re not lighting up the tyres in the first 2/3 years and that the car is gonna go like s**t off a stick without banging 25 psi into it straight away
Sj1782
  Audi s3 8p
My god I love this car!! Hahaha went for a blast to fill up fuel for Blyton tomorrow and check the camera height. Think it's in a decent position thank you Mr roll cage for the support.
Should hopefully get some decent footage tomorrow all being well.
Is it a diesel? Sounds like a pigeon
dann2707
Wish me luck
dann2707
Unbelievable day.
Car performed amazingly well, I boiled my fluid many times and I definitely need new driveshafts due to it still bottoming out slightly but other than that the car performed flawlessly.
I got through a full tank which involved me driving there and back 160 miles so not too bad I guess. I have just got home and got one hell of a smile on my face. The power was just right for the conditions today, the weather was weak in places and managed a few slides but hell I absolutely loved it.
Got some pro photos on order and I gotta say, they look absolutely ace.
dann2707
So guys..
Little update as to my plans before Cadwell at the end of the month.
I've removed the brembos and they are currently at a powder coaters near me. They're shot blasting and powder coating for £30 all in :eek: I looked around at their work and it looked excellent so fingers crossed it holds true to my brakes.
I will be then rebuilding the seals up as I bought a kit recently. Excited to get stuck into that as it's something I've never done before.
Today I flushed out the old coolant and will be filling the new coolant tomoro. I removed the thermostat and flushed it through everywhere till it was clear so fingers crossed it won't go manky soon.
I also fitted a new boost controller today as my N75 gave me grief (apparently) on the rollers. I say apparently as it wasn't 100% certain that that was the issue.
I have a few other jobs to do....
Need to raise the suspension
Order new springs from pure motorsport. Need stiffer springs up front.
Weld the hole in my floor. No biggie but would be nice to get it sorted.
Nut and bolt check.
Omg f**k I completely forgot... I bought the photos from the track day!!! I will get them in here ASAP.
dann2707
Hey guys,
Finally on the computer for some small updates.
Some pictures from the past few weeks:
Mapping when I had to change the rad super fast.
20180426_151034 by dann2707, on Flickr
20180426_153842 by dann2707, on Flickr
La track day
20180428_135829 by dann2707, on Flickr
20180428_122234 by dann2707, on Flickr
Sometimes you just have to plough no matter what the weather / girl.
20180428_152405 by dann2707, on Flickr
20180428_160423 by dann2707, on Flickr
Sitting well afterwards
20180428_160549 by dann2707, on Flickr
Then last week I removed some vital component for powder coating.
20180504_144542 by dann2707, on Flickr
I also tried moving that hub and f**k me.............the bottom ball joint was barely hanging on. Perhaps that was my vibrating issue on track or perhaps that was the secondary failure mode. tightened it up and raised the suspension so i'll never know now.
I must say, using my ex's tights was the best thing ever for coilover covers. Simply unsnipped the cable ties and peeled back and the adjusters are SO free. Good idea. Also really good for prancing around the house in when you're so so alone.
Then yesterday was ace. it involved welding which I'm always scared to do on my car.
20180512_124309 by dann2707, on Flickr
So my gym and old biking mate came around to try this cool welding technique. Basically, when I fitted the pedal box I used box section welded to the footwell, removed that and left some disgusting holes. This technique involves holding a piece of copper or alu behind the hole (weld wont stick to it) and allows the hole to be filled in. safe to say it worked f**king amazingly well.
Befores:
20180512_124316 by dann2707, on Flickr
20180512_124321 by dann2707, on Flickr
Afters, does need sanding back a bit more but the holes are gone so it's all good.
20180512_155454 by dann2707, on Flickr
20180512_155459 by dann2707, on Flickr
20180512_155507 by dann2707, on Flickr
then filled her up with coolant
20180513_152456 by dann2707, on Flickr
then went to the pub with @James172C ! He's buying a moose.
20180513_171452 by dann2707, on Flickr
dann2707
Another Sunday update. Had an absolute blast the last week.
Forgot to say I drove to work in Boris which was interesting. I bet I looked like a massive t**t suit / smart attire in rush hour traffic in the morning...
2018-05-20_08-59-11 by dann2707, on Flickr
So I got my brakes back from the powder coaters on Wednesday. Definitely the best £30 i've spent in a while. I'm trying to fathom how they even made money from it as they popped the pistons out, sand blasted and powder coated them and the finish is excellent.
This was before. @leeds2592 this is all your fault. He kept reminding me how badly painted they were you see... haha
20180428_111611 by dann2707, on Flickr
So that night I needed to get them rebuilt with the new seals but I also needed to go to the pub to see @James172C and @Panda sooooooo let me introduce a new fun game and it's called re-building 4 pot brembos at the pub
20180516_192917 by dann2707, on Flickr
20180516_194040 by dann2707, on Flickr
All on with new stickers
20180517_195235 by dann2707, on Flickr
Yesterday I went to @leeds2592 's house to do some maintenance work on his car
That went really well. I'm hoping i've convinced him to get an ugga dugga after these absolute beauties coming into their own. Can't stress how much I love the combo of them together. One for running bolts, one for undoing pretty much everything you can throw at it.
2018-05-20_10-03-51 by dann2707, on Flickr
Today I got a new phone, the camera is incredible so wanted to take some pictures of Boris. Met up with @James172C to show me a good camera spot and then we went to the pub after. Was a great day.
At the pub we had some interest in the cars, got a photo of some guys perving haha.
Load of pics with new phone incoming...
IMG_20180520_181736 by dann2707, on Flickr
IMG_20180520_181717 by dann2707, on Flickr
IMG_20180520_183003 by dann2707, on Flickr
IMG_20180520_181429 by dann2707, on Flickr
IMG_20180520_181956 by dann2707, on Flickr
IMG_20180520_181601 by dann2707, on Flickr
IMG_20180520_181515 by dann2707, on Flickr
IMG_20180520_194551 by dann2707, on Flickr
IMG_20180520_201151 by dann2707, on Flickr
Strong fan base in Derby haha
20180520_193933 by dann2707, on Flickr
I need phase 2 lights now. Wanting to go back.
Cheers x
dann2707
Today I repainted the driver and passenger footwell as I had welded it up recently so was full of.... no paint.
Also hoovered and cleaned the interior. Took some pics. Mega happy with it now
IMG_20180526_201910 by dann2707, on Flickr
IMG_20180526_201828 by dann2707, on Flickr
IMG_20180526_202256 by dann2707, on Flickr
IMG_20180526_201917 by dann2707, on Flickr
IMG_20180526_201755 by dann2707, on Flickr
IMG_20180526_202316 by dann2707, on Flickr
IMG_20180526_201819 by dann2707, on Flickr
IMG_20180526_202313 by dann2707, on Flickr
IMG_20180526_202335 by dann2707, on Flickr
IMG_20180526_201957 by dann2707, on Flickr
IMG_20180526_201903 by dann2707, on Flickr
IMG_20180526_202235 by dann2707, on Flickr
mintno1
  Ph1 172 / Mk1 Valver
Looks great, bet it goes well now as well ? been out in a 230/240bhp clio turbo and it was plenty quick enough, especially when it hooked up in the dry, would have kept up with lot's of more expensive machinery
