182cup & 172 racecar
If it's been corner weighted correctly, then it will not be the same height both sides.
Okay will get some cup ones then.
Along with that I will get a N/S balljoint.
Just hope it sorts it out. Is there a possibility an incorrect balljoint could be the cause?
Can you explain? Sorry for my stupidity lol.
Ahh so it should sort the issue then.
Chances are if it doesn't something has bent although it drove fine before getting the balljoint.
Sorry for the thread hijack but is there anything else worth changing other than the wishbones? just for a general refresh.
Often when you corner weight a car you need to set the height slightly different on one corner relative to another to get the distribution of weight correct.
Obviously first you should always move weight instead, but as a final resort, you have to do that sometimes.
Any of the following that show signs of wear or play:
Strut top mounts
Track rods
Track rod ends
Steering rack bushes
Dampers (cup ones are an upgrade)
Cheers mate thanks for the help just hope changing the parts resolves my issue at the same time.
If it doesnt then the subframe or shell being bent are most likely I would say.
Unlikely unless it was so harsh it popped the tyre and bent the rim etc.
I'm not sure mate I didn't do it just put it in a local garage for an mot and it failed on lower balljoint O/S.
What do you want pics of? both the front wheels?
So to be clear are there just 2 types of bottom arm??
1 type for a PH1 and PH2 172
And 1 For the 172 Cup and all 182's
Also does anyone know the Renault part numbers for these arms?
FLOL @ one of each.
Could be useful if you are doing oval racing I guess.
No, ph1/2 172's and 182's share the same lower arms. It's just the 172 Cups that have their own variation of lower arm, which has more caster than the other Clios.
Lol that was my issue I asked for your opinion on in another thread, turned out I had 2 different wishbones on
Was good at turning left and I always got tyre sequel pretty early when pushing it round a right hand bend.
I was driving the car for over 6 months like it and was pretty used to it tbh.
It's the 182 Cup pack suspension that I want to know about though... i.e. are my current arms the same as the 172 Cup ones or not.
All the 182's are the same as the Ph1/2 172's, apart from the 172 cup. Like I said, all the Clios have the same lower arms other than the 172 Cup.
Thanks Nick. Now to see if Renault can find the part numbers on the system.
Right, with the help of Colin at Wests we've established that there is something wrong with the Renault parts system! All variants of 172/182 come back with the same part number for wishbones!
The only option now is to get a part number for them.
Colin, look these ones up...
7700430765
7700430832
Cheers.
