Same deal, spray on, blast off?
			I like C2V3 but it doesn’t really last long and doesn’t bead anything like the hydro2 did. I’m after something fairly long term.
What happened?
Same happened to me. Was going to finish machine polishing all small areas today until i saw the dust on mine. Cant be arsed to clean it off nowDust.
One of those cheap hand held steamers should do it!Someone has managed to get some sticky horrible sweet stuck in my rear carpet. Ive tried freezing it and pulling it out carefully but its just pulling the carpet apart.
What other options do i have ?
Anyone used a steamer ?
You're using it wrong, it's diluted, it's out of date.I like C2V3 but it doesn’t really last long and doesn’t bead anything like the hydro2 did. I’m after something fairly long term.
Agree I don't really use them at all anymore. They just offered too much risk without heavily diluting them.I’ve had bad reactions from both Hydro2 lite and AF hydrocoat. Both left terrible staining on dark cars.
I’ve gone back to using C2v3.
I like them for topping up wheel protection!Agree I don't really use them at all anymore. They just offered too much risk without heavily diluting them.
i dont know what sweet it is, but it sticks like s**t to a blanket.One of those cheap hand held steamers should do it!
One of them has happened. C2 is a tremendous product. I've seen 6 months on the right car.
I’ve got a bottle of Hydro2 Lite that I’ve had since my clio... I’m assuming it’s pretty fooked by now.
Is there anything better these days? I know when @Daniel put it on HOU before he sold it to me he just gave it a quick going over and it was still beading fantastically when I sold it.
I don’t think the stuff goes off so should be fine.
Hydro is still best I’ve tried however I’ve been using AF Aqua coat recently because you can get it in Halfords, smells nicer too.
Bilt hamber SurfeX HD...What APC is everyone using used verso last time and works well next to order some more just wondered if any better / cheaper alternatives??
Used auto finnesse aqua coat since it came out do not use on hot car rinse very well and you will never have any issues👍
Great on wheels too😉
If you like spray on rinse off products Gyeon wet coat is still the daddy...aqua coat is good as is carpro hydro, but not on the same level as Gyeon wet coat...Yeah I've always sprayed it on a panel at a time then "shocked" it into the paint with the pressure washer on full bore then rinsed.
Turtle Wax seal n Shine. It's on my wife's carnormally use Hydro but this stuff beats it hands down.
Is Gyeon wet coat a good base for applying a wax on top of? Dont normally wax so but since I got a bunch off someone on here I'm down to give some a tryIf you like spray on rinse off products Gyeon wet coat is still the daddy...aqua coat is good as is carpro hydro, but not on the same level as Gyeon wet coat...
You can apply a wax on top of wet coat but it defeats the object,wet coat is a product that once it is applied and rinsed off that is initially your LSP.If you put a wax on top of it you will lose the water sheeting and self cleaning properties of Gyeon wet coat, and it would be replaced by what ever wax that you apply on top of it!....thats why I rate wet coat so much as once applied,rinsed,and dried off your good to goIs Gyeon wet coat a good base for applying a wax on top of? Dont normally wax so but since I got a bunch off someone on here I'm down to give some a try
Wurth are great quality and not silly money. Should do well.Does anyone have a good brand of pressure sprayer that seems to last with something like Surfex HD in it?
I've bought a couple over the last few months and even though I depressurise them each time, the seals randomly seem to give way and it won't hold vacuum.
Be interested in a recommendation for snow foam pressure bottle too
In the past i was using Meguirs APC, but since the rise of Ceramic coatings I’ve recen gone for G-Techniq W5 Citrus based Ph Neutral APC . I’m pleased with itWhat APC is everyone using used verso last time and works well next to order some more just wondered if any better / cheaper alternatives??
This guy. Awesome things!Mesto
I've had the same two for like 8/9 years now and still going strong
Yes very good, with detailing their is a term called overload, these products are designed to make your life easier for example... say that you did not have enough time on your hands to wax your car after washing it,Gyeon bathe + is perfect for just that type of situation as it's a wash and go type of product...Wash car,Dry car and your Done!Well priced too, Ill give it a go.
Is the bathe plus worth a go also?
