engine mount position
Car  182
Could someone tell me or post a picture of the correct position of the engine mount (timing belt side).
Mine does not look right seems as if the the plate part that bolts to the body via 4 x 16mm bolts has moved?
So now as you look down on the mount there is a large gap between the front rubber bit and the C shaped bracket and the back rubber bit is touching the back??
if that mkes sense?
:o
