Are you going to be doing a wiring guide for this mate?
Just about to order all my bits, this has been a helpful guide so far!
You get a very good wiring instruction manual with the box off ebay - the wiring is actually easy
Removing the old rack is a b**ch and getting the EPAS column in without removing the bottom half of the dash is VERY fiddly.
I had to remove the motor (2 bolts) then fit it - then put the motor back on with the column kinda half in and half out twisted at an angle so I could tighten the bolts to the motor again. Not much fun. You need some patience
Blanked off my rack and fitted the EPAS column today, all was going well until I noticed my ECU had a broken socket, don't know how i didn't notice that. It arrived sat morn and I fitted it all this morning. Where did you get your middle power feed plug from? I need one of those, James got one from a clio being broken on ebay.
Hoping that it may still all work and the ecu isn't damaged. I've asked the eBay seller - breakers in Doncaster - to send another one. Then James told me the ecu is coded to the motor -bit of a mare, don't really want to remove it all. Getting the rubber boot in correctly was a right pita. If it comes to it hoping he'll agree to just send the top half.
Got my column/ecu from Renparts and it came with the middle connector and 3" of power/earth wire - very handy
That break is a bit of a b**ch as that's the side where the clip is to hold the connector in - think it'd just keep sliding out without it
I'm not sure I can see any way for the motor to be coded to the ECU - the only connectors it has is a large power/earth feed from the ECU... and I've read several places where people have fitted new or refurbed motors to their EPAS column as they apparently fail quite a bit.
I think you should be fine to just get another ECU and fit it
Unless the ECU is coded to the torque sensor but again from what I can tell that's just a power/earth and 2 signal leads
It'd be weird if they locked the ECU's to racks..
I know what you mean about that rubber bottom section - it's a pig to get it back through and lined up etc..
I had to lengthen my column a bit by sliding the bottom joint down and it fell off! LOL
So then I had to measure each side of the rack to make sure it was dead center - then center my steering wheel and try to put the knuckle joint back on in the right place so that the whole lot was centralised... without turning any of it... all on my own... not fun
