How much downforce does the 197 diffuser give?
  Clio 1970000000
I have read in articles that the rear diffuser on a 197 actually works (unlike the fashion statements that everyone else is putting on their cars :dapprove::dapprove:) and am curious if anyone has some facts on it.
Just for the pub conversation of course:rasp:
  RS200
thats what i love about the 197/200 all the fancy bits are there cos they increase the performance of the car, not just for show
  Turbo LY R27
Wow 70kg is very impressive! Yeah all the fake ones make me laugh, the corsa one looks awful. Does the focus RS diff do the same job or is that another useless one lol!
  RS200
apparantly the front wing in the 200s grille also channels air to the rear arches and to the rear diffuser to give it even more downforce
Gaz_
  Extreme mode
Cant see it myself tbh, i'm sure it needs a flat undertray to keep the airflow clean........ it looks mint though :)
Tom
  EV
^ 100% wrong.
[FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]The downforce generated by the diffuser means there is no need for a rear spoiler [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]to counter the phenomenon of lift. For optimal stability, the system reduces lift by a factor of three and produces the equivalent of 40kg of rear downforce at very high speeds without (on track) detracting from the car's carefully honed aerodynamics designed to achieve a low CdA.[/FONT][/FONT]
It might be a small amount, but its functional.
  Meg 250/E36 Touring
So would a 200 have less downforce?
As the pipes now take up space in the two outer parts of the diffuser? Must have an effect....
Gaz_
  Extreme mode
If you hung 40kgs off the back bumper it would fall off, especially being a Renault. Its only clipped in with, iirc a few of 10mms near the rear beam
Think about it ;)
Tom
  EV
No idea, ask Renault.
Its in the press documentation. Thats all i'm quoting from.
(Its unlikely that they would make this stuff up, but you know more than me obviously however judging by the "hanging 40kg off the bumper" comment you don't know a great deal about aero ;))
  Tangoed Works
lol at hanging 40kg off the rear bumper!!! Go back to bed.
The underside of the 197 is pretty flat and the diffuser gives the air a smooth exit essentially creating a low pressure area underneath the car.
This essentially sucks the car towards the ground. With regards to the 200, if you look closely you will see the pipes are enclosed within the diffuser so as not to disturb the air exiting from underneath.
Gaz_
  Extreme mode
Oh hum.......
Its no flatter than a 172. And no i'm no areo expert, the comment was made in jest, but obviously lost in translation..........:rolleyes:
Anyway, Cup racers still need a spoiler to clean up the air exiting the roof to diffuser.
  Williams 3
FWD cars do not need a rear spoiler, as they are useless. Ask yourself why a FWD car would need the rear wheels forced into the ground, when actually its the front ones that need the downforce.
The BTCC cars all have spoilers, but this is for aesthetics. They have even admitted this.
realnumber 1
A lot of front wheel cars have the rear spoilers to give the air a smoother flow off the back which can help with stability rather than give it down force. It can also help improve economy due to having less drag.
Iirc they had to add spoilers to the back window surrounds on the mk1 Sierra hatches because of stability issues at high speed.
  Clio 1.2 16v
FLOL. Spoilers on FWD cars also help keep the rear end planted, hence why many stripped time attack cars have huge ones.
ForceIndia
  Gentlemans spec 200
FFS. Some very gullible people on here. It's for show.
IIRC the brochure for the 182 spoke about cup spec tyres, unique to the cup spec'd car.
  RS RIP
little fast cars , heavy engine in the front. Needs downforce on a light rear end, simple.
Renault learn a lot from their F1 technology (aerodynamics galore) ; along the years more + more of this knowledge is used in the production cars. Also at lower cost because so much knowledge has been built up already ; less research needs doing
These 197 and 200 Clios, why do you think they have such a good rep of "sticking" to the road ? A lot to do with the things talked about in this thread
ForceIndia
  Gentlemans spec 200
Sorry, I don't believe it at all. Marketing jive, pure and simple. Pretty sure a 182 has bugger all rear downforce, yet can bang in pretty much identical lap times.
surely it must do something beside just for asthetics????? otherwise you would just be carrying extra weight.
ForceIndia
  Gentlemans spec 200
It looks nice. It probably weighs bugger all, but it's a great bit of styling. It's not a race car, not every part on the car is functional.
I'm no aero expert, but I would have thought a 197 would be more likely to require downforce at the back because of it being longer?? Thats how its adding up in my head anyway.
Someone do a lap with the diffuser on and one with it off? lol
ForceIndia
  Gentlemans spec 200
And lol at 'downforce'. Diffusers reduce drag and lift, they don't produce downforce.
so warren...what your saying is that the diffuser might just serve a purpose beyond 'looking nice' lol. this is a funny thread.
