Reviving this thread too for any future internet travellers! Here’s a quote from the official UK press release in 2009 when they released the new facelift RS200 model.
“Clio Renaultsport 200 is also equipped with an
air diffuser, an aerodynamic feature normally only found on high-end sporting cars. Air passing underneath the vehicle is channelled via the flat bottom to the diffuser where it accelerates before being expelled at a higher speed. Combined with the shape of the diffuser, this creates a zone of depression under the car, sucking the chassis to the ground. Compared with a conventional wing, diffusers generate significant downforce without resisting forward movement. On a track, at 80mph, lift is reduced by almost 40kg. The diffuser is designed to function in association with the rear flat bottom which leaves space for the exhaust silencer and lateral-mounted tailpipes.”
Link to the original article:
https://www.press.renault.co.uk/releases/116
While this may be marketing speak, they seem very confident. And I’m sure there’s some law here that if they state actual numbers, they can’t be lying otherwise that’s false advertising. Therefore surely the diffuser must be functional, atleast to an extent.
