Ive just sent a lengthy PM to paul@rstuning about immobilisers, weather they are hardware or software on the ECU itself....so we shall see. Thing is, ECU clinic was £150, if I have to spend a similar amount again I may aswell have done aftermarket in the first place![]()
Saying that, if its software, they managed to put the complete wrong one on....the 1.4 crap.
For all we know yet, Matteh's might have some random map on too, his was done at the ECU clinic, with his 6k cold and 6.6k warm limiter....Im sure we will find out today though once hes tried a few things.
hopefully geesus will let me know about his emulator trick....im hoping that will mean the immobiliser is sorted via hardware so it can be mapped whenever and wherever without re-activating the fooking immobiliser too!
give me 1k+ and i will, ive spent double that rebuilding engines!
Where is the emulator from james?
I may have found a way around it, i got the key/decoder ring/uch etc with the car, matteh has worked out a way that should work wiring it up to get it running again....going to try it shortly.
Paul @ rstuning supplied and fitted the emulator.
