525i, 66' Bug, Civic
Heres what ive been upto recently, 5.5" narrowed beam with adjusters welded in. Had to weld a couple of small holes in the towers and cut down the bottom edge so i can go low
Then got it mounted, its on the original bolts atm but will be replacing them as the threads are fooked
Got all the best ball joints together, fitted the steering damper, box and kyb shocks i picked up for free
Cleaned up the various bearings and cylinders etc
will take the backing plates to be sandblasted, as i was told the brake shoes contained aspestos?
Found this spring in the hub aswell :S, remember hearing a crunching sound - turns out its obv not the wheel bearing
