Clio Trophy #343
Sounds good mate looking forward to seeing at llandow
U after a dogbone mount ????
What does RS2 mean? Different engine?
Fitted an rs192 exhaust, really nice and easy to fit and looks quite nice in the cutouts.
I assembled with a fair amount of sealant and an uprated clamp and seems ok so far but will keep an eye out. Can always chop it off and weld on a new flange if its a problem. Made the exhaust on the last car anyway so used to doing stuff like that.Keep an eye out for cat-centre section joint blows. The female side doesn't quite curve round enough!
Different inlet manifold mate.
Bit like throttle bodies but designed to work with a shared plenum and standard body so you can retain cruise control etc.
Edit: JMS RS2 Inlet Manifold??
Yup!
Was hoping to see your track car put through its paces
Did think it was strange when you said front one had gone, never known them to be any trouble.
Glad you got home alright anyway, thanks for coming.
We did Llandow for the burpspeed day yesterday, hopefully some other people got pics too, this one courtesy of sharky.
Had a good day and the car is handling great now that I've swapped the suspension off the black one onto it.
Noticed the difference in pace though compared to the black one when racing the Williams trophy yesterday, as in the black one I could keep with them on the straights (theirs is standard engine but stripped and no aircon etc so a lot lighter) but in this car they were visibly quicker, so hopefully once the rs2 is on we will be back to a good match despite ours being full road weight still like the black one was.
Still had a good little battle though even if this time its me being followed on the video while they shout abuse at me into the camera for holding them up not the other way around like I did to them at Combe as is out traditional banter when out with each other. FLOL. So hopefully they will upload that at some point.
Got stopped short by about an hour by a noise that I thought at first was a front wheel bearing but on the way home last night it became apparent it was the rear one. They were changed with gen Renault ones just before we got the car so might be some stub axle damage so will strip that all off the black one to swap over as well.
Use 4th ffs.
Looks good on track chip. I take it this has the cooksports fitted?
