New Clio 182 Series - 750 Motor Club
Be a Ktec system aswell I expect.
So just another over priced cheap stainless system that the mounts will fall off and the tail pipes will be 2ft long.
I'm quite keen to see how long the engines last with Ktec maps on them. Watch them all expire before the end of the first race lol
I expect they've sponsored a lot of the Setup costs. I did see something between RSTuning and Ktec a while ago and David had a pop at Paul saying he must still hold a grudge about not securing the deal...
Quote taken from organiser:
plus seeked tuning specialists knowledge of the add ons and common upgrades to determine the 182 cup choice, its not been a guess.
So chose the top best performance Clio, its also the most up to date.
this is what throws me... From what this says, the have chosen the "optimum" clio. So by this logic anyone who enters in any other mk2 clio is knowingly running a less competitive car thus hindering themselfs. So why is this an issue? If people think they can win in a "lesser spec" car, let them!
Sounds absolutely fine then :) Well picked up.
Lol. Good point.
I'd rather s**t in my hands and clap. It sounds like the racing equivalent of selling your soul to the devil.
Also, KTEC racing maps, actual LOL!
"Here, come and race, using a company who's mapping has destroyed countless engines. Don't worry though kids, KTEC will rebuild for £10,999 plus VAT"
It should be more along the lines of
Any Mk2 Renaultsport
Standard suspension, or coilovers (maybe with a max RRP)
Any exhaust
15" wheels (for costs) (widths and tyre size could be fixed)
Any discs and pads with standard calipers and no brackets for larger discs etc
Standard transmission
IDK on management tbh
Totally agree with this. Our car is still standard 172 ph2 (apart from the modification to the subframe we made and polycarb side windows); still on standard power with 15 inch wheels, standard brake setup with uprated pads, standard transmission, off the shelf coilovers and a very much standard ECU. The only thing that has really changed is we made a cold air box in place of the normal air filter housing...... And I bet it's quicker than any of the cars that get built using the regs given for this 182 series.
A "cheap" entry level series needs to be that.... and not a marketing exercise for a company. You could easily just set out what you are and aren't allowed to modify on ph2 172s and 182s, like a list of allowed coilovers and a couple of control tyres. Then, an allowance on items that might affect the weight, so this would include keeping the standard dash, not chopping bits out of the door etc. Then of course, standard transmission and standard ECU. Perhaps also split it in to 2 classes, 172 and 182 and away you go.
I can't be arsed to look it up as I'm on my phone but are the regs for the other single makes restrictive to the point of forcing you to buy from one company like this?
The MR2 series...
Class A: Mk1 MR2
Class B: Mk2 MR2
Class C: Mk3 MR2 (MR2 Roadster / MR-S)
Engine
Engines may only be prepared within the specifications laid down in Toyota's workshop manual. All engine internals must be standard or standard pattern parts and the factory ECU must be retained. Induction and exhaust systems are free (excluding manifolds).
Class A: 1.6l 4AGE 122BHP
Class B: 2.0l 3SGE 158BHP / 172BHP
Class C: 1.8l 1ZZFE 138BHP
Suspension
Suspension is free but may not be adjustable, with the exception of anti-roll bars. Uprated dampers, lowered springs and polyurethane bushes may be used.
Brakes
Brake disks must remain standard or standard pattern while brake pad material is free. Braided brake hoses may be used and ABS systems where fitted as standard may be retained.
Transmission
Standard gearbox, gear ratios and final drive must be retained. Factory limited slip differentials may only be used on class C cars as these were standard equipment. No other class may use an LSD.
Wheels
Wheels must be standard diameter, width and offset for each class of vehicle.
So it seems they could actually have opted for a similar ruling with the management as per the mr2 series?
I make it not just the management...................
Class A: Mk1 2.0ltr Williams
Class B: Mk2 Ph1 172
Class C: Mk2 Ph2 172/182
Engine
Engines may only be prepared within the specifications laid down in Renault's workshop manual. All engine internals must be standard or standard pattern parts and the factory ECU must be retained. Induction and exhaust systems are free (excluding manifolds).
Suspension
Brakes
Transmission
Wheels
Simples.............. No?! :S
When we spoke to 750mc at the Autosport show in Jan, they didn't really seem to know what they were on about. I think they had been misguided by outside agents as to what was required.
Insisting on 182 Cups for a start, this is a no goer, and does that suspension fit a cup hub??
Keeping 16" wheels is silly, as said above, the tyres are so much more expensive.
I wish you luck with this, but I think I will stick with the French Trophy series run by Track Attack.
​Plus we don't have to go to one supplier for suspension or an ECU.
As I said earlier today.
Repeating what's been said, seems like ktec have won a watch here!
These pointless regs are only going to put people off. I wonder how a ktec ECU'd car would compare to a OEM one. That could be a funny test to watch!
Seems to me that 750 and ktec have started this series for a gap in the market that isn't there.
Simple logic would suggest that starting a Clio race series, the first point of research would be the worlds biggest Clio forum that already contains several successful Clio race Teams.
And tony hunter.
It seems that 750 were down the pub when this idea was born. "Who were the people involved with Ali G's Renault? KTEC, let's ask them what we need."
Are all entrants getting a run on their rollers?
Let's not turn this into another Ktec slating thread, that's not what it's all about.
Just think 750mc have listened to the wrong people about what, and what wouldn't be a good idea.
I just want to reinforce that 750MC is a very well ran motorclub and one of the oldest in the U.K with some of the most popular race series. Top boys and girls just incase anyone was thinking differently :)
I wasn't saying otherwise Sam, a lot of people started racing with them.
​I just think it is an opportunity missed.
Have to agree with sam, everything I have heard and experienced of the 750mc up until now has been very positive, just a shame this looks like it has been ballsed up.
Absolute opportunity missed. How many on here wold already be at least halfway to having a car that could compete if the rules were rewritten similar to what Anonymous posted above. If I did still have my 172 Cup that would have been exactly what I was waiting for.
Will also echo comments about the 750MC. Always been a good club from what I've read/heard.
​That's why French Trophy is going to succeed.
I'm sure there's a few on here that could be tempted, if it was using almost standard cars. But to splash out the best part of £2k, on what most would deem unnecessary parts just seems ridiculous. If it was just a case of strip the car, fit a cage, cutoff and extinguisher and get suited and licensed, I'd be seriously looking into it. As it is though - no thanks. I think for that money, I could make a quicker car for another series. For the record I love other 750 events too.
I agree on it being a huge shame, it's the sort of thing I'd get involved I next year if it were more like I outlined.
A cheap way into racing, where you won't be out spent by competitors, giving you a decent chance.
Exactly Rob, just a simple next step from trackdays. OK there's TT but just to have a "cheap" basic Clio field would be great.
