Mr Trailer Man
		Yeah they’re about £650
Yeah still not too bad.
What brand is the extender? Tempted to get one for my meg.
				anyone know what this part does ? It’s just sort of flapping about in the back of the car
It does yeah. I'm really not sure if you'd be able to tell between the two with rigidity/handling.
Half cages are basically just an elaborate harness bar is the way I look at it. At least with the iso points, they're proper reinforced areas.
The brakes are a lot better with the winmax pads but i've still got quite a lot of trave on the pedall - maybe an inch before anything happens. Worth bleeding them?
morris racing i thinkDefinitely.
What fluid are you on?
Yeah easy enough, hopefully the bleed nipples on the brembos aren't mega seized.ok - looks a fairly straight forward process
Yeah i use SRF too, can't beat it for pedal feel i think.Defo worth a bleed. I am a big fan of Castrol SRF, but it's mega coin compared to the likes of RBF600/660.
One of my pals always used to cry about his until we bled it up using CLiP. Personally I've never had an issue with a pressure bleeder like this (i imagine there's cheaper alternatives)
I’d assumed mine was the same because it was a non genuine one. I guess not!
See the pic on the first page. There’s no daylight between the spoiler and brake
Nah, just sent it and left itDid you have to bend it to fit properly ?
Looks spot on as is tbh!Cup spoiler on. Needs to be nimbus ideally but cba to get it painted
View attachment 1699282View attachment 1699283View attachment 1699284
