shiftspark
R53 GR86
Hey Russ, 1st off what a good job.
I was going to try and fit some dcoe carbs a while back but decided it wasnt worth the hassle but this looks like a better job.
Just a couple of questions for you ?
Which Jenvey manifold have you used and do you have part numbers so I can price up the bits.
Also the pipe you have used for the Map sensor does it need to be a certain volume.
What about the idle, on the ph1 it uses the black hose that draws air in around the TB, is that what is on the end of the Map "pipe"
