Power Tool Perverts
JamesBryan
Sound, aye they seem to be quite scarce in the UK. Anything I see is US based and I know I'll get my face raped with import fees
Aye, think Dan imported his. That guy gets a load in at once so it's worth while.
MLB
Since this has turned more into a Milwaukee thread I'll ask my questions here.
Mainly interested in the stubby impact wrench and m12 ratchet, would I be best to get these in 3/8"? I've got a 1/2" makita impact wrench.
The die grinder looks brilliant for rust removal (rear beam, undercarriage etc) but would it be worth getting when I already have a corded dremel? Would the dremel take the same sanding discs?
dann2707
100% get it in 3/8 mate, they are great for smaller jobs where access can be tight. I got it in these because I have significantly more 3/8 sockets, they're small in size in comparison to 1/2.
It really is a match made in heaven having those two tools for Dismantling and assembling/fitting bits and then use the 1/2 big boi for the stubborn bolts and big jobs.
I genuinely can't stress how much those two tools have helped me when working on cars.
  • Like
Reactions: MLB
jameswrx
Seems logical to get a 3/8” if you’ve got a 1/2” already but then again if you’re equipped with 1/2” sockets there’s no reason not have it in 1/2” I guess.
If you do go 3/8” I’d recommend getting some deep or semi deep impact sockets though. They do fit in smaller spaces but you might find your makita actually fits and works with a shallow socket whereas the Milwaukee has no nose poke so bare in mind if you’re trying to poke it in somewhere the flat front is in line with your hand and means it’s not as practical as you might think.
Pretty cool little beasts though, mine looks beat already (no boots available when I got it). Battery tech has certainly moved on these days, have the 6.0amp battery and it lasts ages.
  • Like
Reactions: MLB
MLB
Thanks for the info guys!
I've only got a standard Halfords 175ish piece tool box for sockets at te moment which contain only 1/2 inch impact sockets so @jameswrx good tip for the (semi) deep impact set for the 3/8. If you had to choose, which would you get, deep or semi deep?
Any particular set/brand recommended for 3/8 impact sockets?
dann2707
I would get both. I have shallow and deep sockets. They were both cheap at around £25 a set thst covers everything I need
  • Like
Reactions: MLB
JamesBryan
I got these when I bought my 3/8 stubby.
Not cheap but not expensive either
MLB
I was looking at that one!
And maybe something like this https://www.toolstoday.co.uk/frankl...mi-deep-thin-wall-impact-socket-set-3-8-drive
as @Pudding of Yorkshire said, better have ALL the sizes!
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Good value those for what they are.
I can see me buying an impact gun soon. Only problem is I'll want the M12 stubby but the drills I have for DIY are both M18.
It's a slippery slope once I go down the M12 route. Heated jacket 😂😂
YorkshireKyle
Not all gingers stink of piss. But I do.
I've got 1/4, 3/8 and 1/2 sockets in short, medium and deep length, chrome and impact of all types too😂😂
Honestly Halfords and US Pro have been good for me and I'm a right abusive c**t when it comes to tools😂 90% of my hand tackle is cheap stuff, I just have a few snap-on/Bahco/Teng bits that I've found on jobs😂😂
clio_ross
  Clio 172
I bought a 3/8” to 1/2“ adapter so I can use my 1/2” deep sockets and allow wheel sockets with mines. Worthwhile investment for under £5 and makes it even more versatile.
  • Like
Reactions: MLB
jameswrx
I did buy some deep 3/8” Bosch impact sockets but the set misses a 14 & 18 out, they are really well made though and a lot thinner than most cheap impact sockets.
Otherwise my stuff is snap on impact wise (shorter ones and I have the wobble ones etc)
I’d never actually bothered with deep 3/8” impacts before the Milwaukee but did find I needed them when I got it going from my snap on impact gun. I try not to get credit with my snap on dealer but the cash deal on a 3/8 deep set was crap.
I would say though these days there really isn’t that many bad cheap tools out there. When I was young it seemed unless the ratchets and sockets were snap on or Mac they were like xmas cracker stuff.
Think it’s ‘Expert’ (ex draper expert) I handled some stuff the other day, looked really good actually. Pretty sure it’s something to do with one of the bigger brands (was it Facom or blue point?)
But then again I’ve had a set of flex head Halfords ratchet spanners for donkeys. I think they originally made them really well and may have changed. Back when I got them sure the snap on ones were still these horrible weird flat plate looking things. I bought a set of Mac flexi ratchet spanners years later to ‘upgrade’ and I’ve broken loads of the Mac ones and not one of the Halfords ones has broken ever!
JamesBryan
I thought that chrome vanadium sockets weren't exactly suitable for impact use because they're more likely to shatter on an impact wrench?
Chrome Vanadium is the type of metal, not the actual finish.
Although typically most sockets are then plated in a chrome finish, which adds to the confusion.
MLB
I thought that chrome vanadium was too brittle for impact use hence special sets made of chrome molybdenum which flexes and bends instead of shattering?
That US PRO set is made of chrome vanadium according to the description and as seen on the sockets (picture 5).
Heat treating and tempering will only make the material more prone to shattering or not?
jameswrx
Blue point are still snap on but with a different name
Draper are Britool or King Dick if youre really old😂
That’s it, Britool makes expert (former draper expert to get away from draper name) Under same banner as Facom too?
Pretty sure modern blue point stuff is just rebranded Chinese stuff like laser etc? Certainly looks very similar to all the other cheaper tools with the blue point name just stuck on. I have a few bits and just looks like the stuff you’d find in the motor factors on the wall of shame.
JamesBryan
I always understood that chrome vanadium was too brittle for impact use hence special sets made of chrome molybdenum which flexes and bends instead of shattering?
Ahh yeah, you're right.
My Teng ones are CR-MO I think.
YorkshireKyle
Facom and Bahco are good quality without busting your pockets wide open. Blue point and snap on new stuff is pretty poor from what I've seen of my mates gear and they've even resorted to copying Milwaukee. Imagine being one of the biggest hand tool manufacturers and half arsed copying ideas from other 'smaller' tool manufacturers😂 I keep showing my mate my Mileaukee stuff, he's easily spent 20 grand on strap-on shite
The old Snap-on stuff is good enough to survive the apocalypse.
Louis
I Love Ed Sheeran
I mean I've ugga duggad the arse out of them and they're absolutely fine.
  • Haha
Reactions: MLB
MLB
Haha I suppose they wouldn't be in business anymore if they weren't any good, that's good to hear! I was just wondering because my normal set is chrome vanadium which would save me buying a new set or sockets entirely if they're usable.
I may need to do some more homework anyway , there's too many options!
Louis
I Love Ed Sheeran
I think on air tools it's probably a different story again! Sometimes it's good to remember if you're only using them every other weekend theyre obviously going last a lot longer. If you're buying tools for work I'd recommend differently as you dont want to be halfway through a job and having to buy more tools when they break.
MLB
Ah right, didn't know that!
And good point definitely a difference if you rely on your tools every day to make a living instead of just trying to keep a 16 year old French box on the road from a wet driveway. Good to try to find the balance between cost and quality.
JamesBryan
I think if you're only busting nuts and bolts at a few hundred Newton metres chrome vanadium will be ok.
It's generally the 1000Nm stuff you'd want chrome moly sockets.
  • Like
Reactions: MLB
mikekean
  996 C4S, 135i, E30x2
Britool 'Expert' isn't anything to do with Draper. 'Expert' is just Facom's rebranding of Britool. The Draper Expert range still exists.
MLB
I'll see if I have time to do some tests this week and let you know. Otherwise it's coming to Oulton Park 16th of January!
