Rear Suspension Problem - 182 Cup
I have a 2005 182 Cup thats practically brand new with low kms.
The problem is I fitted semi slicks to the car and under extreme cornering (track work) the rear suspension bushes flex and the tyres are rubbing on the inner guards/bodywork.
I checked the clearance, its the same as the standard wheels/tyres but they don't generate as much grip as the semis to cause a problem. Its only when I run the semis that it rubs.
Powerflex don't do rear bushes, does anyone know of a solution to this problem or of someone out there who does polyurethane lower rear bushes for the 182 Cup?
I considered the 3mm spacers Loony, I think spacers would be a good last resort option if I can't fix it properly.
Fred its a stock 182 Cup with 15x7 ET45 rims and 205/50R15 Toyo R888 tyres.
The R888s are a little fat for 205s but the clearance is practically the same as the standard wheels/tyres - Its around 10-12mm between the tyre and the box section of inner bodywork just behind the left side of the rear bumper.
Any other ideas?
I'm thinking a rear swaybar might do the trick. I have a feeling there is too much grip at the rear causing it to toe out excessively.
