Reattaching Lower inlet manifold
  Golf GTD Mk7
Is there an easier way of doing this? Was a pain in the arse to get off. There are two nuts right under the alternator bracket which were a b**ch to undo. I'm just worried i'll not be able to tighten them up enough. Any tips?
  03 RS clio 172 flameR
it is fairly easy, just a pain in the arse, if you look at my guide to matching the inlets yourslef, i ended up hoisting the engine out or ease of access. but wouldnt recommend,
  Astra 1.9Cdti SRi
cant you just take the front panel off, slam panel i think its called were the bonnet latch connects to? should give you abit more room :)
loosen drivers side mount or even undo it, then jack the engine on the sump a little to get clean access to the bolt.
  Golf GTD Mk7
It's not the side bolt I going to have issues with. It's the ones which are obscured by the alternator bracket. There are two of them at the top and bottom I think, drivers side. I jacked the engine up slightly on one side to get to the side one.
It's not this that gets in the way really mate. But i did think about removing that :)
  Golf GTD Mk7
not really danny, its the alternator bracket in the way. So have to go in at an angle. Presumably you can't remove this without messing with the belts?
  BMW M135i
I'm not really sure which ones you mean? I've never had a problem with it tbh, the only slight pain is the side one which wants the engine raising slightly but thats no biggie either tbf.
  Golf GTD Mk7
the two bolts furthest left as you look at it. Very awkward to loosen I found, so replacing them will be interesting. Not the best space to get to them really.
  ITB'd MK1
Can't remember the last time i changed one without the belts off at the same time. think if you take off the brace from alternator top bolt to block it'll help, and use a UJ on an extension or a bar with a wobble end. Sure it goes in there
  Golf GTD Mk7
thats how I undid it, with a bendy end ;) but don't think i'll be able to get the right tightness on it.
Danny you saying that the bar which supports the alternator to the engine can be removed without compromising the aux belt?
  "Navy" N17 TWO
Everytime someone has asked that in a few threads, nobody has replied :(
  Black Gold Trophy
I just use a long extension with a universal joint.
The snap on extensions have wobble ends on them too which gives you slightly more flexibility to get at the bolts
  "Navy" N17 TWO
Cool, anyone got pics on what needs removed? lol
I wouldn't want to make a balls of things :eek:
