Service Result :(
Car  Clio MK2 (1.2)
just got the Clio back from the Garage, was suprise to see how many thing he Advise's me to do :dapprove:
Carried Out full service,
Replace Timing Belt Kit(£91.47)
Drill Out 1 o/s/f wheel stud
fit new bulbs on n/s/f side light and number plate light (both went last night:mad: )
Oil (£30.00)
Oil Filter(£5.70)
4x spark plugs (15.40)
Alternator belt
adjusted handbrake and rear shoes
total : £242.57 is that good?
the advise he told me was well :dapprove:
Rear wiperblade torn - knew about it but never use the dam wiper,
rumble in o/s/r wheel bearing
front suspension needs to be lifter - as when full lock the whel rubs against the spring :S
n/s/r tyre near 1.6mm wearband (more cost)
front pipe exhaust blowing (inside broken)
so car is booked in to get the bearing done in 2weeks:)
overall happy with the outcome as e managed to get the emissions light off the dash:approve: (touch wood) brakes feel better duno what he did but their more responsive, + of good service he washed the car to :D
i would say that is an ok price to pay..... however the list of advice he told you...mmmmmmm
"front suspension needs to be lifter - as when full lock the whel rubs against the spring" what does that mean?????? new spring??? bushbes???? new strut?????
im suspicious!!!
its on coilovers, so im guessing just to lift it up a bit, but if i do that aint it still going to rub? :S
