Sky Glass
jenic
What are people's issue with Sky Q?
I have a fairly new (8 months old) HDR box and it's brilliant. Works perfectly every time, the UI is imo the best out there, no sound sync issues which I'm quite sensitive to, and great picture quality. My only criticisms are inconsistent parental controls across channels (but I think this is an overly protective BBC issue) and no DV support which means I still resort to the TV's Netflix app.
Oxyuris
  Clio 172
So the new HDMI leads seem to have fixed many of the problems, which is as surprising as it is pleasant. It does seem quite odd but since fitting the puck has behaved flawlessly.
However I've just sat down to watch MOTD which has just finished. It is in my playlist, so should be 'recorded' to the cloud, but I cannot because Sky is now directing me to the iPlayer app and it's not available on there yet...
Big Toe
  Clio Campus
Usually goes on after midnight
Oxyuris
  Clio 172
Usually... however it's still not available.
But the problem is I'm now paying for a SkyGlass subscription whereas a similarly priced Sky+ or SkyQ subscription would have just recorded it for me. I've always been able to watch it on iPlayer but have never needed to because it's just been recorded for me by my Sky box.
Big Toe
  Clio Campus
This is exactly the reason why I won’t be switching to Sky Glass.
Oxyuris
  Clio 172
It could be great but the pucks are a real let down and not being able to record anything to any cloud is verging on mis-selling. However with my situation I'm going to stick with it and keep my fingers crossed that things get better.
Another fault I missed from my massive moan further up is that it keeps forgetting that I've paid for UHD and have a UHD TV and changing the resolution, so I have to manually change it back. Unfortunately this happened again this morning so the new HDMI lead hasn't cured everything.
  Clio 197,with megan'
HDMI leads cause many problems, make sure the cable you buy is HDMI certified, it will tell you on the packaging.
172PH1
  Ph1 172
I won a sky glass tv with UHD package and sports and cinema through work for 12 months. Got to say the 55 inch tv is a bulky old thing aint it
We've gone from virgin media where you can record stuff as like many other packages so not being able to record or set reminders takes a bit of getting used to
However the picture and the sound is great
Cannot complain really for a freebie through work
  • Like
Reactions: Ben
  Abarth 595
Another bad point for Glass. Cant order BT box office through it, so all a bit of a ballache for the boxing tonight.
