Smoothing bumpers.....err....how
want to get rid of the bump-strip on my valvers bumper, presumably by riding it away, but someone has told me that they are actually hollow! This would mean that if i grind them each bumper will split in two - is this actually the case??
Also, whats the deal between phase 1 and 2 bump strips? Can i replace my ph1s will ph2s??
the bump strip on the bumpers will pull off it isnt the easiest thing to do but it does come off, just held on with clips, as for phase 1/2 strips yeh they will fit, they just slide forwards then pull off ...
no james.....the bump strip is part of the bumper.......only the insert can be pulled out yes if you remove it your gonna have problems
