Sony MD head unit troubles in my 53 CUP
1
172Petey
Bought all the correct InCar Tec leads from car audio direct and it all works but the ATT/MUTE function comes on when you turn the ignition switch to the first position, (as if both the volume buttons on the remote stalk are pressed, which pauses on the O.E head unit) then when you turn to the next the ATT goes off an when you start the engine (or final ignition switch position) the ATT will come on again. Its only some thing small but anoying. Any one had the same problem, and how was it solved? :dapprove:
Sounds like the wiring looms been done incorrectly. its feeding the power down the wrong wires at the wrong time.
