Ur pipe like everyone eles will.probs come tomorrow. Its getting plenty of cold air bein located being the headlight so it shouldn't. Post up ur opinion when u have it.all fitted up
I'm guessing once you remove the air box the notorious acoustic valve will no longer come into play?
On a another note does just fitting a decent panel filter and removing the acoustic valve not have a similar effect/sound to all this?
Gonna experiment if the stuff comes today
have a look at this mate
Fastcar Clio 172 Air Filter Test http://www.cliosport.net/index.php?threads/Fastcar-Clio-172-Air-Filter-Test.445339/
So in other words it'll lose one or two of its horses with this kinda set up... The plus being it'll sound mental :smilingimp:
what type /size filter is on the viper?I have been using a viper with a cold air feed, and have ordered this set up so I will be able to give my Input on the difference once I have mine set up! the thing with the viper will be the actual filter size, the surface area will be smaller so less air will get though? from what I understand again, correct me if in wrong!
also see this for my test I carried out (posted a few pages back) http://www.cliosport.net/threads/1-...ter-a-short-article-reveals-the-truth.699570/Yeah I Supose so... They did test the piper cross which has it's own heat shield and what I assume is still the standard air feeds so there should be no heat soak and it was still down on the original panel filter read out?
The ktr set up like this suggest they get a few more horse power so guess thats probably right.... Could take the headlight out for extra cold air :tongueclosed:
removed down to the acoustic valve, no need to remove valve.Is anyone leaving the original air flow pipe (to air box) in place or are we removing it to maximise the air it gets?
yep :up: the pipe terminates at the acoustic valve so you cant get it wrong.
also see this for my test I carried out (posted a few pages back) http://www.cliosport.net/threads/1-2-induction-kit-location-–-does-it-really-matter-a-short-article-reveals-the-truth.699570/
nice work :smile:I had a similar idea last month, did mine slightly different but still the same concept!![]()
Thanks [emoji1]. Yeah it's a 70mm filter! Initially it was a bit fiddly to get it to sit perfect behind the headlight! Biggest filter I could fit there!nice work [emoji2]
Is that a 70mm filter? If so it should work on my setup also (although it doesn't look that much bigger)...
I'm off today, i reckon it's turned up though :smile:
