Rob
It's not minor. Honestly. You can really feel it holding back, well I could.What, the CDA?
I'm really not fussed about 4-5bhp here or there.
I meant make sure the filter is ok as in it hasn't collapsed or something like that since fitting...Afaik the filter is set up correctly.. and although the difference is minimal, I can feel it. But as mentioned, it only happened after a very very long drive. It's not often I drive so far so I really aint all that bothered.
pipe finally turned up today with a load of deep scratches and a few dents! hopefully get it fitted tomorrow.
Cable ties? Wheres best place to put them?
post 1 would have shown you! And this post a few pages back!!!Cable ties? Wheres best place to put them?
Ok hopefully these will show what I mean about cable ties and alignment (and it shows why you need an offset neck!)
how shes looking at the mo!
10bhp gain...seems optimistic!
This is a Ramair filter btw...I'd avoid them like the proverbial plague!
that's not happened from normal use! the mesh would wither get squashed in but the foam pulling in on it or be sucked into the engine completely. not sure whats gone on there! what type of filter is that anyway as it looks very small at the other end?10bhp gain...seems optimistic!
looking forward to seeing yours on FridayJust checked my filter after a few days of hard driving and still looks brand new. Will keep a eye on it which you should any open filter
It's a RAMAIR. It's an old old pic c2005. Possibly a different design, but I'd still avoid themthat's not happened from normal use! the mesh would wither get squashed in but the foam pulling in on it or be sucked into the engine completely. not sure whats gone on there! what type of filter is that anyway as it looks very small at the other end?
No I meant what type as in cylindrical / cone etc?It's a RAMAIR. It's an old old pic c2005. Possibly a different design, but I'd still avoid them
I inspect what is happening is the ecu is detecting knock and pulling out ignition timing. You should log knock correction and ignition advance after an ecu reset and the same when you feel the power drop. Probably just needs a tune.
