What do you mean when you say missed a gear?
Great results for Sam. Shame about your race, but as you say lucky there wasn't a pile up behind you.
Thanks Mark, It was a good day really all said and done and we will be continuing with the French Trophy at either Combe, 27th May (car may not be ready in time) but definitely Brands Indy at the end of June. Won't be going back to Tin Tops.Good work by Sam.
Bad luck for you.
Was it a good day? Are you going back?
I was watching both races on TSL and wondered where you were. Real shame
Good to meet you and Sam today chap, car was great, even in its 'temporary form'![]()
Sounds like a day of mixed emotions which is a shame after all the hard work to get the car thereWell done on the qualifying really good place to start the race and sounds like Race 1 went well. Sorry to hear about the new(old) engine thank god it wasn't the new one phewwww!
Congratulations to Sam job well done, sorry to hear about your troubles Pete.
Congrats to Sam well done.
Sorry to hear about the misfortune!
Wish I was on commission for all these Epas's lol!
Shame about the limp mode rearing its head againpersonally I would be getting rid of the stock loom, Ecu and UCH and getting a standalone on the car before doing the engine that way you can run some different cams to suit the high comp and also add proper reliability to the electronics. Much easier to map reliably too
I seem to remember saying that about 12 months agoShame about the limp mode rearing its head againpersonally I would be getting rid of the stock loom, Ecu and UCH and getting a standalone on the car before doing the engine that way you can run some different cams to suit the high comp and also add proper reliability to the electronics. Much easier to map reliably too
horrible noise as he went for a gear at the end the the straight before turn 1, Bit of a guess until i get to pull it apart but it looked like going for 5th and getting 3rd (or 4th/2nd, not sure) causing a massive over rev. There's no compression on cranking anyhow. Literally a slung in spare engine I had knocking around so not important, but annoying that it ended the race, especially after the last few days work
OMG, that cake. Unbelievable.
Engine plans sound good, i'm looking to get a 'practice' engine so I can get alot handier with the spanners. You are right to focus on the Limp mode issue chap, as it could have been pretty 'interesting' on the start line if you were further up the grid, which will be the case now you know the qualifying laps rule for shared driver teams.
Shame about the Gopro drying...happened to me (as well as others recently), Any one know the battery shelf life?
Sounds like a plan regarding the engine and cam belt Pete. Im doing a engine swap at home soon, not done one before, just been doing a lot of reading up on how to remove it. I will also be stripping my old engine down and rebuilding.
EPAS seems like a good idea too, been reading a lot about this in another thread, may look into this at a later date.
Hi, whats the reasons behind not joining tin tops again? If you don't mind me asking.
Any videos of the race?
I was going to say the same about the std loom.
The day could have been better, but then again, it could have been far, far worse. Good result for Sam anyway, and I know you'll both be back.
Cake was.....................yummy.
Nice to meet you on Saturday pete. Shame about the engine issues. The cake however was, well, immense!!!
Ouch, very unfortunate. At least it was only the spare, still very annoying none the less. Same happened to Porkie on the Bedford track day I think.
Thanks, Dan's explained for me.
Cheers Jay, yes would've like to have thought my charge from the back could have been impressive but coupled with being at the back, the limp mode issue and not getting away when the lights went out meant I rushed and maybe panicked, leading to a wrong gear selection in my haste to catch up with the pack. It was lonely on the grid on my own.
Cheers Oli, cake's the word.
Yes James, my sentiments after the moment!
Thanks...
NP, Sam had cracking drive just pity the go-pro stopped working after the qualifying session.... battery fully charged the day before, flat after qualifying, a right Ar3s. New battery on order now.
The plan is now I'm going to take the engine out at home and get it back to Dan's, seen the engine out and in once with Dan and it's within my capabilities. I even think with all the right tools the cam belt is now no mystery.....ha ha famous last words. Don't worry, I'm getting a high mileage engine to practice on, swapping the engine in and out (will need to be a runner though!). I'll leave the cam belt for now...
Will also ditch the PAS while I'm there, get an EPAS column, blank off the cup rack and hopefully get all this sorted before the next race. One less thing to worry about plus will make loads of space in the engine bay.
The only real concern I have is solving the limp mode issue, as this really could have been catastrophic going into limp mode on the start line like that.
Quite an easy car to miss a gear in the Clio gearbox. Not good when its a fairly expensive engine as they don't like 12krpm.
Belt is pretty fiddly with engine in if you havent done one before but is very easy with it on a stand.
Pete.... I assume you have the GoPro 2. If so, you should really get a Skeleton housing, far easier than getting spare batteries and having to swap them all the time.
http://gopro.com/camera-accessories/hd-skeleton-housing
We've just wired in a simple USB socket and plugged straight in to the camera, then can just leave it in the car and only have to tend to it when we run low on memory.
http://www.ebay.co.uk/itm/3Way-SOCK...668?pt=LH_DefaultDomain_3&hash=item5aefbe0234
This is the exact thing we've used. We just cut the plug off the end and connected it in with another 12V feed... make sure it works with the main cut off though.
Sorry Pete i meant videos of the actual race not on board footage.
I do have a feed near where the camera goes for the intercom and camera just never got round to setting it up though! Will now, yes got a Go Pro2, whats the noise levels like with the skeleton case. With the sealed one it's at a good level.
EPAS bit's all ordered, controller £50, electric column (both parts, ecu and rubber boot) £60, two m12 bolts £2, M18 blank £5, and M16 blank (clio sump plug)£5 - all off Ebay
All my parts for my EPAS conversion has arrived - so will get on this over the weekend and also get the engine out.
Any one know if I can take all the rack PAS pipes off the rack without removing the rack???
Yes you can do Pete if the engines out, I would remove and check/replace the rack bushes if required.
Cheers James, Can I remove bushes (if required) with out upsetting the track rod's? Don't want to have to re geo but will if have too.
