Viper Fitting Help
Rich-D
  E90 LCI 330d
Its easy to fit mate, just remove the standard stuff, then fit the filter onto the original plastic inlet hose, then attach the cold air feed to the other side of the filter. No brackets required, it will just sit there.
The cold air feed pipe can just be fed down to behind the front bumper, theres an obvious gap when you remove the standard airbox.
The small filter you also got is for the oil breather, but Id not bother with that and leave the standard setup with the opil breather running into the intake system.
HTH
