225 Clio Build
Trying to all the silly little jobs yesterday and that to keep my interest in it, yeah was in stus Cossie last night and he was teasing me with the boost which isnt fair, very nice what you bought?
Yeah I bet that thing shifts!
A white Mk2 Focus RS, thought may as well go full out or nothing lol
Well still no got my turbo yet as the guy it was sent to from my engine builder decided to do any work to it at all in 3 months.....absolute raging to say the least,
So to keep myself sane I've been ordering a few parts so I can still work on the car
Order list as follows
powerflex steering rack bushes
Powerflex inner arb bushes
Powerflex outer arb bushes
Brackets to fit brembo brake calipers from www.spead.co.uk
300mm scenic discs HC brembos
Mintex 1144 pads
Brembo rear pads
Ate super blue brake fluid
R26 injectors as been let down on 630's
Also picking my brembo calipers up on Wednesday so hopefully that'll keep my busy until I get the turbo back
Not good on the turbo front! What turbo did you go for? Hybrid, wasnt it. Hope it turns up soon!
Sounds like there still a few jobs to do so at least its not totally stopping you.
Yeah going hybrid
Brakes were all ready on the list but poly bushes were just decided over the last week, thought might aswell do them now when I've got the chance... Wishbones will be done at a later date as I'll be going for cup wishbones I think
Parts just keep turning up
Thanks to g172 for suppling my discs, pads and brake fluid great service as always
Finally got some work done tonight since the ph1 it's behaving for now..... Inner and outer arb bushes changed to powerflex ones steering rack bushes changed and brakes build up all and all a productive evening even if I drop a socket into the subframe
I assume your brackets have shims because the callipers have been machined to fit 280mm discs?
Where did you get them from? I am seriously considering going up to 300mm too.
Mines haven't been machined mate
The brackets came like that with the shim, SPEAD get the main bracket made for the 280mm conversion then give you the 5mm shim
Got them off jack Kemps dads company SPEAD.co.uk
Magic - I had a suspicion they would be from jack!
Cheers mate :D
(my lines are HEL ones - if that helps)
Well things are looking forward a little bit, getting a turbo next week most likely standard as Andy as been messed about with the one getting hybrid, so the car will be built but power will be held back until the hybrid is ready but at this stage I'll take that as Andy has offered to fit the hybrid for nothing once it is ready
Also been and picked these up today there nothin special but it's a start for track and at £100 couldn't really say no
Picking mounts up next week and I'll get a second harness from somewhere
Nice one Wayne :clap:.
I was looking at your brakes a couple of nights ago when I was up the unit with Stu, I wish you had the smaller disc set up so I could of tried some of my 15's over them.
What was the problem with the hybrid ? Ive only ever used TT and CR turbos and been a week at the most even for a custom hybrid.
Well finally it has appeared pity it's only the standard one tho
Just waiting on the return fitting which Andy forgot to put in the box the I can start to rebuild the car
Also could wait to find another harness soon when and bought myself 2 brand new 5 points
Well had a change of heart today while phoning for prices getting turbo hybrid
I ordered a megane 250 turbo oops shall have it tomorrow
Also fitted 197 HEL brake lines to my brembo calipers along with 5 mm spacers which has helped my clearance issue
Good choice on the turbo. Is it a straight fit? Did you speak to Braveheart Developments about a hybrid?
Is there enough length on the brake lines when on full lock?
