Is this garage having my pants down?
  PH2 172, Kangoo
Easy way to check if it's the dephaser, at idle it will sound like a tractor/clicky/horrible noise. The noise should go away about 1500rpm or under load. If this is the case then it's the dephaser. If it runs like a bag of nails throughout the rev range then he messed up, simple as.
Sounds pretty suspect that the cam locking tool wouldn't fit.
welshname
If it's idling like crap then the timing is out. I'd suggest they haven't a clue what they are doing. If you can get them to send you a picture of the horse shoe shaped tool in the end of the cams. If you're timing is spot on you should be able to do this with it in place:
Mr Trailer Man
Ive already phoned trading standards and basically it looks quite a bit of hassle. He says he's only charging me for the dephaser £186 and not the labour, and it needed doing anyway because it was on its way out, the evidence for this he says is because the camshaft tool wouldn't fit at the start. He says normally when he resets the dephaser for the tool to lock the camshaft at the end, 9 times out of10 it works, but this time it hasn't worked.
There was no noise from the dephaser when the car went in and now he's saying the tool wouldn't fit in at the start, is this even a genuine problem that a failing dephaser causes?
Pretty sure you don't 'reset' the depasher pulley to get the camshaft locking tool in.
They've fucked it.
R3k1355
They've made a f**king mess of it and are still trying to charge you through the nose for their s**t job.
loggyboy
The only way a dephaser would break would be if they physically damaged. If it was silent before it wouldn't just go - and if it did go it would be a light rattle. a worn dephaser just carrys on working, but with a noise. It would not cause issues with running etc.
You are being roggered. However its gonna be fun and games to ensure a fair outcome.
I would:
Tell them you know its not the case that dephasers 'just break' after taking expert advice.
You believe they have made an error and you want the car returned working at no extra cost.
If they refuse tell them you want the car with nothing owed, and you will be taking to an expert to report/repair and they will receive the bill thats over and above whats been quoted.
If you have paid or are forced/inclined to pay to get the car back - pay on a credit card.
  Clio 182
Cheers for the advice people, really appreciate it.
Just wish I'd have done a bit more research before letting this clown loose on me car.
Honestly don't know what im going to do with it here cos he isn't going to give me the car back without paying for the job, despite it being fucked. And I dont trust that if he changes the dephaser its magically going to correct itself.
is this cambelt change on a 182 exactly the same as it would be on any other clio or megane etc.?
I'm going to see him now so will keep you's updated
Ol’ Tarby
  Clio 220 Trophy
He may class hismelf as a Renault "specialist" but he certainly aint a RenaultSport and F4R specialist.
The timing procedure is quite sensitive on these engines, and its very easy to balls it up, which it sounds like he has.
I think this is going to be an expensive lesson as I can see you taking it somewhere else to rectify it, if he can't do it himself.
  Clio 182
So according to him the F4R is the same as changing the belt on a D4F, Ok then...
Aye this is what he's been saying, they're all the same apparently, he's done hundreds of them.
I said so youve done hundreds of 182's have you? And his reply was no but they're all the same. He's never done one of these by the sounds of it. Also he keeps showing me a programme on his computer telling him how to do the fucker, surely a renault specialist wouldn't have to refer to drawings and instructions?
He's had me life here
  172 Turbo
Renault Specialist -> 1.2 Clios & 1.6 Meganes
v
RenaultSport Specialist...
Also, I believe the program he is using is wrong on the belt change
Mavez
  Clio & No Megane
v
Yeah probably dialogys, which if I remember someone said had the incorrect instructions on locking the cams to loosen and re-tighten.
leeds2592
  Bean 182 + E70 X5
Sounds like an expensive mistake to make. I know it's no use but that's why I took mine to Mick at Diamond Motors.
Scrooge
  E55 AMG
Yep, 180 out isn't possible at all.
What's happened is; they either haven't evened out the tension across the belt therefore the belt has lost tension or they didn't put the tdc pin in correctly.
Or they've done it all correct but are trying to milk you out of a little bit more money.
welshname
Having both 180 out could be done, but the top bolt wouldn't go into the cam cover. Does sound like he's got the TDC pin in a balancing hole though. I assume he's clever enough to get the tools in but the balancing hole is far too easy to do
  Clio 182
I took mine to Mick at diamond motors he's really good at doing them he let me watch him do the whole job I traveled from Leeds to Nottingham just to get it done all genuine parts used its worth traveling
Scrooge
  E55 AMG
But the engine would contact if it was 180 out
  MG ZR x2, Polo, CTR
no, as one cam will have the slot above centre, and one will be below.
---------------- __________
Align them with a dead straight line.
If both are 180' out, then the securing bolt won't fit.
But you'll also get 16 bent valves fairly instantly
  Clio 182
Hello mate... I know this probably isn't of great help to you now, but for future reference if you need your car sorting in Newcastle,speak to Trevor at DTM Cars. They deal in Renaultsport Clios all the time and are genuine specialists. I bought mine there and it's been no bother.
loggyboy
It is possible to set one at 180 as I have done it. luckily I noticed before I got too far. Its less likely if you bolt the tool to the rocker, but if lazy he may not have done that.
  MG ZR x2, Polo, CTR
I have absolutely no idea how you managed that then as even without bolting it in, it won't slot in properly unless to tool is bent.
I've only ever seen it done once, and that was by a garage using tippex.
They diagnosed an ECU issue as timing being out, so reset it with the exhaust cam at 180'
loggyboy
Of course it will, it means both cams will be a little bit out:
  Clio 182
Yeah mate ive spoke to Trevor a couple of weeks ago as I was looking at a different 182 he had for sale. Genuine bloke who seemed to know what he was talking about, felt a bit shite going to him as I went and bought a different car a couple of days later.
