Mr Trailer Man
Just fitted my camber bolts and had them dialed in to -1.5 deg.
I'm now thinking the inside edge of the tyre might be too close to the suspension spring, especially on track under hard cornering.
I can just get my fingers in the gap between the two, so say roughly 10mm +/-. Is that enough?
Would it be worth getting some 5mm spacers for a bit of extra clearance just in case?
  Teg
What offset wheel you got pal? Just fitted camber bolts on mine and getting it aligned tomorrow for neg 2 degrees... I've got cup turinis so hoping I'll be ok now.
