Updates galore! Made some decent progress this weekend and last.
@bashracing came over last weekend to do my timing belt for me. The guy is an absolute whiz and he managed to do it in an hour or so. Thanks again mate!
Then
@Matty1303 and
@leeds2592 came over to mine for pizza, beers and a night out. Was a great night and lovely to see them both :smile:
Me and matty arranged my nuts and bolts into these lin bins that arrived! So good to have them organised like this.
We then began to wire up the engine with the clio harness
And found some discrepancies with some connectors. The clio phase 1 throttle body uses a tps as it's cable operated so that was one of the issues. Also the Tdc sensor in the gearbox was different, as was the map sensor connector. Fairly simple fixes though.
Popped my wheels on and rolled Boris forward so I could get a washing machine in around the back. Got me excited to get it sorted as I'm sick of driving a slow car for work.
The next step was to change the throttle body wiring so that it runs with the phase 1 tps. Massive massive thanks to
@barnesautos for his relentless help with me pestering him for wiring diagrams and help. Thanks Jason
Had to find continuity in the wires of the ecu to the original 6 wired plug,
Labelled up
The next issue is wiring the map sensor in. I'm using the clio loom and the map sensor on the Megane is a different connector so I want to use the Megane map connector on the clio loom. However the clio is 123 on the wires and the Megane is abc or vice versa. I need to get the Megane 225 wiring ecu pin out so I can find out which is 5v, signal and
earth.if anyone can help me that would be awesome!
Clio on left Megane on right
The next job was the wrap this bad boy
Not bad for a first attempt..
Followed some advice online and wet the wrap first. Didn't find any advice online telling me it's fibreglass based so that was hilarious itching like f**k all evening..
I then fitted the uprated 630cc injectors
And a parcel of goodies arrived
Load leveller for the engine and box
197 thermostat
Phase 1 accelerator cable
Flywheel bolts
Flywheel to clutch cover bolts. Turned out they're not m7 on the lightened flywheel so that was a lovely waste of £17
Ttv are m6 for anyone reading this in the future
Changed the stat
When locating the wires for the carbon cannister I found this! The insulation around it was also very brittle.
So I taped them up, wonder what they were causing to go wrong.
I fitted the short shifter today too. That started to become a bit of a ballache.
You have to punch put a roll pin which decided to teach me NOT to use a Torx screwdriver to do said punching. Finally came out after much swearing and abuse. I spanked it to Halfords to get a roll pin kit, two sets of vice grips (long nose and normal) and a punch and chisel kit.
Got it on though. Not just waiting to be told I've got it on the wrong way... Haha
It was fitted like for like for the original so should be correct.
I then started to remove the stud from the Megane gearbox mount. Turned out I could have just used it but I'd have to take apart the clio solid mounts and I'm not sure how they come apart after much head scratching. Turned out I can just remove this stud. And fit with clio stud.
It was a b**ch to remove even with heat but finally cracked it off.
I then fitted the decat to the engine and started to take it off the stand ready to fit other parts
Flywheel fitted with the new bolts
Clutch on..
Then mated the gearbox up with a few bolts to bring it together. Need to clean up the surfaces where the bolts go as I'm not fitting them over painted areas. Finally stuck the load leveller on and called it a night knowing I've made fairly decent progress this weekend.
Should be getting the engine in next week after work, I just need to fit the starter motor too. Then I need a few more parts, oil cooler for one and an alternator.
Thanks
@incy-spider I used your technique and filled the slave with fluid before fitting it by the way!
