Raceface_13
Staffordshire
Hey guys,
Seen a lot of posts (especially recently) about wheel stud conversions failing and loosing a wheel on track, even after being torques up after each session etc.
Are some people unlucky or doing something wrong or are they still a safe thing to do? want to do mine for spacers and ease of wheel fitment/swapping.
Brucefil
  Renault sport Clio
Hey guys,
If you race and are constantly taking wheels on and off with wheel bolts I can garentee at some stage you will forget to tighten them and loose a wheel. And wheel bolts are an absolute pain in the arse
Sent from my SM-A520F using Tapatalk
Jekyll
Although not on track, but I've converted to studs for well over a year on my daily 182 with blasting and never had a problem. Probably done 10k at a guess.
I'm with James in the fact that they are just as safe as bolts.
Raceface_13
Staffordshire
awesome thanks guys, just don't fancy loosing a wheel at the ring :smile:
Just noticed an influx of people loosing wheels, there was a post on Fb and everyone said "ah its the studs they always come loose" thought id check.
imprezaworks
  Mk5 Golf GTI :)
I’m sure like others have no issues, but me personally would stick to what your happy and confident with.
Louis
I Park Like a C**t
I have noticed my nuts 'loosening' off sometimes. I check the torque on them every so often and they often need a little tighten. I mean, they're not at the point of nearly falling off but it's a concern. Could spacers be having this effect on them?
JamesBryan
Depends on the spacers, what thickness are they and are they hubcentric?
Louis
I Park Like a C**t
Try them a bit more at 110 and see how that goes.
You've not got any paint or powdercoat in the bolt tapers have you?
Potentially. I'll give them a clean then tighten to 110. I carry a torque wrench with me now and just check them before/after any long journeys. Take 2 minutes so doesnt bother me
JamesBryan
Then again, you have 2118's don't you?
They don't have any paint in the bolt tapers from factory :up:
Louis
I Park Like a C**t
I believe they've been re-powerdercoated. They also had some horrible plasticote on them so there may be some left behind in there. Sorry OP for threadjacking
JamesBryan
99% of bolts coming loose from what i've seen has been down to paint on the tapers and on the mating face of the wheel.
BRT Motorsport
ClioSport Trader
  Clio Rally car
Could go up to M14
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I've ran PMS stud kits for years and never had issues. I've seen some customers with 2118's have *some* issues with generic hub-centric spacers though. They're normally due to a silly taper on the rear of the wheel Vs a larger chamfer on the spacer. This stops the wheel locating against the mating face properly and they eventually wobble themselves free.
Louis
I Park Like a C**t
I'm running Watfields spacers. I'm not sure what sort of chamfer they're running. Can easily find out.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Easiest thing to try is remove the spacer from the car and place it against the rear of the wheel by hand. If it fits perfectly, you're ok and of there's an issue you'll easily see it.
BRT Motorsport
ClioSport Trader
  Clio Rally car
yes as abouve, tap the hubs to take M14 studs,changed to m14 after shearing m12 studs,changed to m14 years ago and never had any issues
need to make sure tap is straight
Coops Mk1
  Lots of Scrap...
have you had to ease the bolt holes on any of the wheels you use as well?
Coops Mk1
  Lots of Scrap...
interesting, could easily enough machine wheels out provided enough meat though I guess.
make my Superleggera even lighter removing some metal.....flol!
leedsboy
  Bean 182 + E70 X5
Mine have been solid and not loosened since I put them on and torqued them up before CSF.
