K20 powered 172
Chambers_RS
  Clio 172 Cup&Leon K1
7.45am this morning
Chambers_RS
So. Bad times. Yesterday didn’t go very well at all.
Straight from the start the front lambda was not working at all so Chris couldn’t map off that, no worries he said he’ll map it like a race car but it’ll never pass mot 😂
Chris started mapping and done everything upto 2K and all seemed well.
He then started mapping higher up the Rev range. He did 1 full bore run which caused the fan belt to squeal it’s tits off and it pulled really s**t figures.
So we sorted the fan belt before it come off.
Chris did more runs with more s**t figures.
I could see Chris was thinking there’s problem here as he remember how torquey it was last time he mapped it. We did some digging and found the VVt was working correctly.
With the engine idling we unplugged the VVt solenoid and when we plugged it back in it was activating the VVt at idle!! So Chris dived into the Gen90 and found the VVt output wasnt working and had to physically move the pin in the wiring harness to spare output.
Not impressed considering this is brand new Gen90 ecu direct from Ktec.
So after a few more runs and Chris desperately trying to find an answer mapping or ecu related. After yet more runs Chris and I decided it must be engine related either compression is down or timing is out so unfortunately had to leave mapping uncompleted.
I don’t think the timing will be out as it’s barley been used since done. I’m hoping it’s down on compression just to have an answer of why.
Anyway highest figure it pulled was 172bhp and 153ftlb which is about 20 down on each, I didn’t get the graph printed and can’t find my old one either!
I did share my old graph with @NorthloopCup but don’t suppose he will still have a copy.
So I’ve got a compression tester on order to see whats happening there but I’m really really struggling to think what to do with it next!!!
Disappointed to say the least
R29TJR
  2005 RB 182 Cup
Sorry to hear this mate.
Fingers crossed you get it resolved quickly and this will all be a distant memory.
Chambers_RS
Oh yeah please. Legend
I can send it to Scoff then and see if that graph is up across the Rev compared to yesterday’s graph.
If my thinking is right, If it’s down on compression the whole graph should lower through out the Rev range and if it’s cam timing it’ll be up/down in random areas?
haimsey
  ph2 172
Not the good news I was hoping you’d share. At least you’ve got a plan for getting it sorted. Only heard good things about Scoff so sure it’ll be sorted and out on track soon!
Chambers_RS
@NorthloopCup you reckon mk3 200 pistons would make a difference to my setup?
If it’s down on compression I might throw them in as I have them and new rings.
massivewangers
  Several
So you can run the 197/200 pistons with the 1*2 head ok? Didn't know that. I thought going the whole hog and fitting 197/200 head was required, though I don't know why 😂
Does the 197/200 use a high CR than the 172?
Chambers_RS
No point unless you're f**king the rs2 off and also carrying out the necessary to stop it spinning the centre main. To get n/a hp requires £'s. Lots of 'em.
Haha no what you mean. I do like the RS2 tho 😂
Block machined for tagged bearings help that? Like the F7R bearings?
NorthloopCup
It's part of it mate yeah. Biggest issue you'll come up against is the crank in the 736 is shite for high rpm work. Block needs checking for trueness of journals as well - line bore if necessary. Everything also needs to be balanced as well.
Chambers_RS
I’ve got a 200 engine so could use the crank rods and pistons all balanced with the lightened flywheel I guess. I’ve got a decent 172 block as well.
Struggling with what to do actually as I don’t wanna go ITB or turbo really.
gez 172
  Defender 110
Simple. Sort the compression and continue. It doesn't need to go further down the money pit route IMO.
Standard base/internals is reliable.
Sorting the compression is peanuts in comparison and then just get it back on the RR for mapping.
Chambers_RS
Not if it’s piston rings 😂 still be £££s
I know what you mean tho. Need to test it first but once it’s broke it’s the perfect chance to upgrade :tonguewink:
gez 172
  Defender 110
Or buy my lump.. fit that and enjoy the car, and build a spare high spec engine up on the side out of yours haha
  182 Turbo
i love the torque curves on the RS2 manifolds, i bet that feels so snappy low down the rpm range. sorry to hear the recent bad news though mate, hopefully you'll get it sorted.
shoulda just wacked some 197 cams in with some fruity timing for better gains though amiright @JB21 ? 😂😂
Chambers_RS
To drive on track it was awesome instant power from anywhere in the Rev range really.
Can’t remember why I didn’t stick 197 cams in tbh @NorthloopCup may have recommended not using them or I couldn’t find any at the time lol. GrpN timing is really good to drive
NorthloopCup
Take it from me, grp n and be happy. I sometimes wish I'd just left mine with the grp n timing and not gone all out like I did with the engine. However, I built my engine to prove a point.
  Clio RS
Was off work this weekend so set about changing the water pump. I order the Valeo pump that PMS sell. I checked repair times on autodata and when I saw 4.1 hours to change it wasn't really looking forward to the job.
Spoke to a few Renault specialist in my area they all said to loosen the engine mounts and push it to the passenger side and the pump will just squeeze out.
Anyway all I did was undo the 4 bolts to the alternator bracket and the top alternator bolt, pulled it all forward and the water pump was out in 20 minutes happy days.
Sorry for asking, but how did you get so much space between bodyshell and engin?
Course this would of been harder if I still had PAS lol.
10 minutes to clean the old gasket off and 25 to fit back together and tension the belt it was done. Happy days.
Gave the ML a bit of TLC too as it need rear brakes and the rear antiroll bar drop links where missing strangely.
Chambers_RS
The graph/our come wasn’t shared because mark ask me to keep the grpN timing quiet as at the time he was building his engine and didn’t want endless requests for it doing.
I’m sure I’ve said in the thread as well I only brought the manifold to get rid of the horrid join on the standard one.
It certainly has lost any power with the manifold and Im still not interested in figures regardless over how it drives, and it’s really good fun to hammer on track.
