Martin_172
as above if you have a tuner list you can only use tuner lists, and vice versa
Ah will it not? Why?Update list won't work in your motor mate
Just get a connects 2 box. Had one in my dCi 100 and never had an issue with sound quality etc with the cabasse unit
I have an update list though mate to relace the tuner list?as above if you have a tuner list you can only use tuner lists, and vice versa
Update list is 05 onwards, tuner list is pre 05Ah will it not? Why?
In that case it might have been an update list from factory sorry I thought you said it had a tuner list previous.I have an update list though mate to relace the tuner list?
I don't know what it originally came with anyway as it was aftermarket when i bought it, and Kyle sent me a tuner list.
Will be interesting to see what flags up in the mot in January as I haven't replaced anything since all the initial work at the start.Good to see its still grafting. My orange dci is catching yours up on the miles 150k now![]()
182 will fit mate, all mk2 are the same.I had to lose the cd changer to plug in the connects 2.
Not the best audio quality but does the job for me.
I’m also looking for an undertray, will try a 182 one and see if it fits..
I tried the update list last night and it didn't work.Update list is from the ph3 onwards which yours is with it's digital dials. I would try and get an update list cabasse auditorium if you can as the sound quality is far superior to the standard ones. You can swap over the faceplate if you find one from a late 182.
Update list uses an AUX connection instead of the connects 2 device. You need to enable aux in the menu. There's a youtube video on how to do it.
Just saw you have a 2 bulb radio display so this makes sense, updates are 4 plcc-4 LEDsI tried the update list last night and it didn't work.
not all ph3 had them for some reason there must have been a cross over, my ph3 1.6 16v had a facelift front end, digital dials but a tunerlist cabasse from the factory.Update list is from the ph3 onwards which yours is with it's digital dials. I would try and get an update list cabasse auditorium if you can as the sound quality is far superior to the standard ones. You can swap over the faceplate if you find one from a late 182.
Aye it was 2005 mate, megane, modus etc are all the samenot all ph3 had them for some reason there must have been a cross over, my ph3 1.6 16v had a facelift front end, digital dials but a tunerlist cabasse from the factory.
Those indicators on a battery can be a bit misleading.Thanks @gez 172 and @Mazz , i have replaced the bonet sensort with a spare i had and so far no alarm so im wondering if that might have been the problem.
I did wonder about the battery but i know thats only 2-3 years old max and the indicator says its good. I might check with my multi meter out of curiosity anyway.
I also started to wonder if messing with the headunit may have caused it as it only happened after that. Although thinking about it, im sure this happened once a few months back so who knows....
Thanks mate. Multimeter shows 12.9 so its fine. I was wrong though, its the STOP light and the handbrake light that keeps flickering! Any ideas?Those indicators on a battery can be a bit misleading.
I'm going back a few years now when my battery died , had to call out the RAC. The indicator was still green. RAC guy said that it only indicates that 1 cell is ok , not all of them. Changed the battery and the old battery was in my garage and still showing green weeks later.
Get your multimeter on it then you'll know for sure.
Handbrake light is flickering when you're driving , especially round bends?Thanks mate. Multimeter shows 12.9 so its fine. I was wrong though, its the STOP light and the handbrake light that keeps flickering! Any ideas?
Wait!
Get a screwdriver and an old hoover with a bit of hose taped to the end in that inlet!!! That thing is gross!
Have you taken the J-pipe off and cleaned that too?
The inlet mani is cast into the head so you can only clean so much. But the EGR housing can be removed (bit of a pain in the arse)i did the j pipe a year ago when i bought it and it was clean. Strange as i expected it to be full.
The other bit, the inlet? I didnt even know what that was and how you would get it off? I cleaned as much as i could with a screwdriver but it looks like it needs a proper clean. Is it even possible?
I still think it's your turbo on the way out I said this months ago on this thread iirc
I’d say you have a leaky turbo Austin. Think about getting a new cartridge for it with new seals, they’re only around £100.
Also on these 100 is very easy to clean the inter cooler out once the bumper is off, I’d try that too.
Take your intercooler off and pour out the contentsWhat other signs would there be that the turbo is failing?
And yeah, your turbo is spewing, mine was the same when I sold it. Your EGR will just keep clogging over and over
What? Lol. Honestly no idea where i would start with that and what i would need to remove.Take your intercooler off and pour out the contents![]()
Yeah it's a stupid design from Renault! Yeah basically the turbo is leaking oil past small seals around the sore shaft down the inducer shaft and flinging it through the intercooler and then it's making its way into the inlet in small amounts. You can find the cores for them pretty easy or just get a new turboYea looked at it and though how would i get the rest of that off!
What do you mean? Leaking oil from the seals? How would it be resolved?
