Okay so keeping this thread up to date, my “road car” now has the following parts.
Inferno Clio 182 FF & Cup Packs
Engine:
ITG Maxogen air intake
BTM/Yozzasport cat back exhaust
PMS cat derestriction
PhilM exhaust mounts /stainless mount bracket holders.
Transmission:
Quaife ATB diff
PMS motorsport shifter
Suspension:
AST5100 coilovers - specifically valved & sprung for road
PMS topmounts & brace
PhilM dogbone bushes
PMS 19mm Rear ARB
Whiteline rear beam bushes
PFlex Black steering rack bushes
PFlex Black front wishbone bushes
NorthloopCup Roll Centre / bump steer correction hubs.
Braking:
Hel Performance stainless brake hoses
Motul RBF 600
Brembo HC discs
PFC 097 pads
Wheels/tyres:
16” Speedline Turini - Gloss black
Michelin Pilot Sport 3
15” Speedline 2118 - Anthracite
Toyo R888
PMS Spacers +16mm front / +10mm rear
Stud/nut kit
Exterior:
2019 Fiesta stubby aerial.
Genuine Cup washer blanks
Phillips Xtreme Gen2 lighting
197 RS boot emblem
Fabia front splitter
Interior:
Momo Prototipo Classic Steering Wheel
Works Bell rapfix 2
Volantech cruise button panel
Recaro Pole Position ABE seats /JonFoz XL bases
Steering column dropped 8mm.
Alpine 178BT headunit.
Without doubt the most impressive changes have been the dampers, diff, RC hubs and tyres.
Bushes are nice changes that make incremental improvements, but the aforementioned items alone make such dramatic changes to the little Clios capability. None of them have any detrimental trade off either. None of them have increased NVH or have shown any ill side effects. In fact, none of the spherical bearings or bushes have increased NVH either which is a usual side effect. Perhaps the lack of adverse vibrations is because I’m using new OEM engine/gearbox mounts and these obviously transfer no noise to the cabin. Only the dogbone is uprated with the PhilM item and that also transfers no extra NVH.
The hubs require regular and careful maintenance, however that’s a trade off I can live with for the improvement in steering response and stability. The seats have made a huge improvement in driver position and feeling like you’re sat in the car rather than on it. Easily the most usable fixed back bucket seat out there, but they are more work to get in and out than the OEM seats.
So far my “worst/most detrimental” change has been the PMS shifter. Yes the feel and height are a huge improvement, but it’s taken a great number of hours and messing about in order to keep vibrations to a livable level. The BMS/Scenic shifter I found doesn’t have the correct control weight and feels too light. But obviously offers no increase in NVH inside the car.
Perhaps this is an item I maybe wouldn’t buy again and instead buy a brand new OEM item and swap out the lower bushes to brass items.
Tyres are also pretty noisy for road use but I’m no stranger to this and will suffer the increase in tyre noise for the offset in performance.
I absolutely adore this as my idea of an ultimate “road” Clio and will continue to update this and be 100% transparent with my experience.
