Today's job was finally changing the aux belt and tensioner. It's been whining for about 2 months now, and being 5 years since it was last changed I was pushing my luck.
Bought genuine parts from RPD. Suprised the tensioner didnt come with a new top bolt but there we go.
Disassembly is relatively easy. Frustratingly the 120-100mm jubilee i bought didnt have a worm drive that went all the way around so these were too small. Luckily I had 2 spares in another box of parts otherwise it was a wasted strip down!
All came apart easily, I'd say the belt was probably overdue...
Tensioner was free and unseized but obviously swapped it for new. What a c**t to remove. Had to remove the ac lines and pull the alternator forward to get it out! Be easier on a stand for sure.
Idler pulley was also replaced. It's so tight in there that I had to rig my tools just to get bolts undone. Utter pain! Refit was reverse of removal, just remember to leave the alternator loose as this makes getting the belt on so much easier.
Whilst I had the engine mount off decided to remove the ridiculous block of metal that is sat in the bay.
Overall a b*****d of a job purely because of space.
A more fun job was fitting my carbon shaft that has been sat in the garage for months. I have noticed that this version the bottom nut seems to hit the turret when going into reverse? The bottom spacer is dimensioned differently to the previous one that came off? Looks fantastic though and matches the interior trim.
