The titanic has docked…
Dicky Belly
  Whichever has fuel
Have they properly driven it? As in, tried to make the light come on?
A garage I used to use would ‘road test’ cars about half a mile round the block at 20-30mph.
Then I go and collect it, as soon as I hit the dual carriage way the EML pings back on… 🤦‍♂️😂
Ant1
Brembo! Brembo! Brembo!
I said several times it only does it when you boot it, takes seconds to come on once it gets to 3000 rpm. So yes I would think they have but knowing my luck…….
I’ll let the car idle for 10 minutes and I’ll boot it from their garages entrance, will come on instantly if not fixed.
Trainerbrow
  Mk1 Audi TT 3.2 V6
Leave a number 11 on the road outside
Cub.
This is a cruise liner we’re talking about here. Last time someone tried booting something this size, this happened;
  Arctic 182, GTD
Resetting the adaptions won't do anything because it will already have been done after the engine swap. Plug it wouldn't just give you fault for one bank only.
Hate to say it but sounds more like they've ran out of ideas and hoping you take it to then give them a day to catch up with other work, to then re-schedule you in at a later date.
Ant1
Yep very possible but they know I’m going to be on their backs within 10 minutes of leaving and the car will be dumped back on their doorstep.
I did wonder if they have found a fault which they have corrected due to a error in reinstalling the engine but won’t say so blame can’t be placed.
I guess I’ll find out @ 10.30 😂
Shall we have a sweepstake? 🙃😎
  Arctic 182, GTD
That is another possibility. I suppose you'll find out in a few hours!
Hope it is sorted though.. Nightmare of a situation either way.
Ant1
It’s back……
Sorted! They were really good today and apologised for being off (explained but won’t post), collected and went out for a rag and it was perfect. It actually drives much better than when I collected it from Manchester.
He said there were codes stored that my and the RAC guy couldn’t read which may be linked to the loom being unplugged from the high pressure pump which may have caused the issue.
Smashed her all the way home with no problems
Trainerbrow
  Mk1 Audi TT 3.2 V6
*edited
Pipped by seconds
Glad it's back and running well bud. What's the thing stand you at now then?
Ant1
*edited
Pipped by seconds
About 13k which is now the going rate for one. Tbh i would rather have mine with all the work done which includes oil cooler seals, flapper motors, torque converter rebuild, shocks all round, new tyres all round and so on than pay 13-14k and take a chance knowing what they can cost.
Still need to sort parktronic controller and front Sam unit but I’m going to take them apart first and clean up before pumping another 1k into it.
Cub.
It’s back……
